Question regarding the MZ-S
Posted 18/09/2013 - 23:07
You might be better to phone one of the repair houses and enquire. harrow Technical and Asahi Photo spring to mind as obvious choices.
Posted 19/09/2013 - 08:10
This is about the age of the camera rather than the model.
The issue you describe was very common on early models in the MZ range - mainly the 10, 30, 50 and 5. Pentax then replaced the weak plastic cog with a larger tougher plastic one which I believe they used on the M, 5n and 7.
They then eventually gave up on plastic and changed it to brass.
I am not certain but I think the brass ones were used on the 3, 6 and S.
I have been a fan of this range for years and have owned several examples of every model. I have never had the problem with either a 6 or S nor have I seen any reported, whereas I have personally had the problem with examples of every other model - the latest being a 5 that died last week.
Carl
Carl
Posted 19/09/2013 - 09:28
Not good news- I was given a 1996 MZ-5 and took it to the Philippines for 5 weeks - no trouble -- ( YET!! )
Posted 19/09/2013 - 12:24
I would not be too worried - it is the only 5 I have ever had go and was a heavily used model. They are so cheap to replace now in any case but as I prefer the 5n - probably will not bother.Not good news- I was given a 1996 MZ-5 and took it to the Philippines for 5 weeks - no trouble -- ( YET!! )
The 50 is without any doubt by far the worst in my experience - I have had 7 of these die on me and although I still own 3 - I do not trust any of them!
Carl
Posted 19/09/2013 - 13:27
just in the interest of completeness Carl, where does the 60 fall in your run down of models above?
I had a 50 for a while a few years ago and must admit I found it quite disapointing, ended up replacing it with a z-50p
but it does help
but it does help
Posted 19/09/2013 - 13:49
Now you mention it - I have not know this happen to a 60 either. That said, although I own one - it has hardly been used as I have always disliked it - especially the silly little rubber buttons.
Carl
Carl
Posted 25/09/2013 - 08:00
Carl
Agree fully on the 60 Carl, I picked one up a while back but can't be bothered using it because of the buttons.Now you mention it - I have not know this happen to a 60 either. That said, although I own one - it has hardly been used as I have always disliked it - especially the silly little rubber buttons.
Carl
As for failures, so far a 7, 50 and 5. although, to be fair, the 5 was a complete dog from a charity shop (the 7 does have the bad plastic cog)
I keep saying my favorite MZ is the 6, fully usable with DA lenses, infact my 40mm goes on it regularly.
Back to the original question, no idea but would love a play with a MZ-S
Cheers, HG
PPG entries.
PPG entries.
UK
