Question on K7 autofocus speed, etc
Posted 07/05/2010 - 14:18
Thanks for the info, all noted
https://www.flickr.com/photos/carlosimagery/
http://twitter.com/foxycce
http://foxycce.ontheroad.to/carlo-does-thailand-tour
Karma is Just Cause and Effect - Do Good, Good will Happen
Posted 07/05/2010 - 17:31
Amin, I'm going a bit off topic here but do Canon lenses have s smaller throw on the focus then Pentax lenses?
I'm very curious about this because I believe that this might have something to do with the focus speed.
For example the DA40 has a very small MF throw and the AF focus is very fast, the throw on the DA*50-135 is 3 times as long and takes a bit longer to focus.
Since every one says other brands focus faster I wonder if that has something to do with it.
Posted 10/05/2010 - 19:03
Canon lenses vary in focus throw depending on lens model, just like Pentax. The major difference is that their USM lenses, especially the L ring type are much faster than Pentax SDM. Amin, I'm going a bit off topic here but do Canon lenses have s smaller throw on the focus then Pentax lenses?
Nikon, like Canon, also use different types of ultrasonic motors, from cheap micro motor ones in the kit lenses, better micro-motors in the smaller mid-price lenses and ring type in most of their telephoto lenses. I would say that SDM is similar to the mid level types.
Like Nikon, many of the Canon ultrasonic motors feature full time manual focus over-ride, exactly like Pentax quick shift, and many have a reduction gear on the manual focus ring to give a much greater control when manual focussing which is not done on any Pentax lens.
The other factor is the AF processing power employed in the bodies, slow in the intro bodies, faster in the mid range and very fast in the pro range, Pentax don't have very fast (yet! :roll.
Posted 10/05/2010 - 19:14
RichardDay wrote:
Nikon, like Canon, also use different types of ultrasonic motors, from cheap micro motor ones in the kit lenses, better micro-motors in the smaller mid-price lenses and ring type in most their telephoto lenses.
Richard, I think also the kind of focusing motors used in the L ring type compared to the ones used in the SDM lenses in Pentax is what makes the difference in AF speed. There was a thread sometime ago where a member had explained some details about the SDM focusing motor and that if Pentax had used the type of motors similar to the Nikon lenses or the Canon USM ones the SDM lenses would have had faster AF speed. I wouldn't be surprised if that member were you Richard because you seem to have a good grasp on these stuff from the way you explained so well above
Amin Photo Gallery
Posted 10/05/2010 - 20:42
But the motor isn't everything though, it's also the AF sensor and the software behind it.
Wasn't it you Amin who tried a super fast K7 demo at SRS?
Also Pentax is one of the few, maybe the only one that have lenses with SDM and screw-drive focus, many people forget about the complexity that's involved to make that work and Pentax does a double focus check where others only use one.
Posted 10/05/2010 - 22:01
My experience was that you will notice the most difference with screw driven focus lenses, they felt quite a bit quicker on the K-7 compared to the K20D.
The SDM driven DA*s don't appear to benefit much, which is a shame. I'm sure Pentax will be working hard in this area for the K-7 replacement.
I agree with Stefan, I'm sure it's not all down to motors.... but in this case is does rather point that way because of screw drive improvement.
Again in my experience ring type focus motors do show a clean pair of heals to geared micro-motor types and without accuracy suffering.
Still I wouldn't dwell to much on focus speed, the K-7 has many other virtues which for me made it a step up from the K20D.
Posted 10/05/2010 - 23:01
Amin,
There is no need for me to pounce on you.
When you say: "I am definitely staying out of this discussion", and then proceed to make several posts, any comment I might make would be completely superfluous.
Posted 11/05/2010 - 09:01
George Lazarette wrote:
Amin,
I couldn't find a smiley representing tongue in cheek to attach at the end of the first comment
Amin,
Amin Photo Gallery
Posted 11/05/2010 - 12:37
Yuck!
Posted 11/05/2010 - 12:39
Mike, if that image wasn't taken with a Petnax or Samsung you might end up in trouble
Amin Photo Gallery
Posted 11/05/2010 - 21:36
LOL
Victory Mansions
Apparently.
