question about using strobe flash to photograph jugglers
Posted 05/12/2006 - 09:26
David,
Not sure if this is what you want...
Perhaps you could try rear-curtain sync and a slow shutter speed.
Like this:
* Set the flash and camera on a tripod
* Set rear-curtain sync
* Set flash to manual
* Set aperture to, say, f8, shutter speed 1/30s
The flash will "freeze" the motion of the items being juggled, but if you balance the ambient light (along with aperture and shutter speed) right you'll see a trail of their path.
To get the appearance of multiple items you'll need strobe flash along with the above technique. Some of the Metz guns will do this (my 50MZ5 will), and (I think) the Pentax AF500-FTZ.
Far easier is Photoshop (or Elements even):
* Take two shots (as above) in quick succession
* Open both shots in PS
* Pick the move tool and drag one shot over the other - this should make one the images have two layers (you can also use Ctrl-A to select all, Ctrl-C to copy, switch to the other image and Ctrl-V to paste)
* Open the layers tool so you can see the layers
* On the top one, change the layer blend mode from "Normal" to "Screen" (assuming you have a black background in the juggling scenes)
* Now you can erase what you don't want in the top layer.
(It's far easier to show this technique, than write it Check out the layer tutorials on my site: www.mattmatic.co.uk which should get you familiar with the basic terminology and way of working)
Have fun!
Like this:
Have fun!
Posted 05/12/2006 - 09:27
Have nnever tried to capture this but I think you need a flash that does rear curtain sync and a reasonably slow shutter speed. Don't know if your Metz units can do this but the AF360FGZ and AF540FGZ can.
Brian.
Brian.
Posted 05/12/2006 - 09:31
Examples of the slow shutter speed, rear-curtain sync:
http://www.ephotozine.com/gallery/showlargepic.cfm?photoid=195769
http://www.ephotozine.com/gallery/showlargepic.cfm?photoid=197577
Posted 05/12/2006 - 09:40
From what I gather looking on the web (it's difficult to fathom on the Metz), if you have the correct Pentax SCA-3702 adapter for the Metz, then you should have rear-curtain sync (perhaps called "2nd Curtain Sync" available as a little switch behind the window of the SCA adapter
If you're still stuck, then I have an SCA3702 at home - I can tell you what to look for, but from memory, the far left position is 1st curtain sync (leading curtain sync), the second position has two green triangles, and the third has a green triangle/flash - which is the rear-curtain sync.
HTH!
HTH!
Posted 05/12/2006 - 22:32
thanks a lot, I'll print this out and tackle your tips at my earliest opportunity.
Posted 06/12/2006 - 15:29
The AF500FTZ does do multiple flash but the repetition rate is no faster than one every second (1Hz). This is probably to prevent the flash electronics/tube from overheating.
Errata
20Hz (20 times per second) is the fastest multiple (strobe) flash rate of the AF500FTZ, not 1 Hz (one flash per second) as mentioned above.
Errata
Posted 06/12/2006 - 19:02
I have that unit and the flash rate is adjustable, and much more than one hurtz....I'm at school right now and cant look but it'll pulse at least as fast as the af assist function on the digital bodies.
21 years
Anyway, can't see anything in the flash manual about it. Can any of you explain how to do this. I hear people talking about using photoshop, but I don't quite know how that would work either.
Also, for either scenario (strobe effect or photoshop), wouldn't the juggler herself have several overlapping slightly off images going on there?
Thanks all.
