Question about screw-mounts
Posted 08/03/2013 - 17:41
The first version was just a T mount then they brought
out the T-2, they are both usually interchangeable.
Quite a lot of pre-set lenses used them including
Russian made telephotos. So a Jupiter 11A 135mm M42 can
be converted to a K mount by swapping the T mount.
Posted 08/03/2013 - 20:10
If you look on Wiki.. about T mounts you will find out the specs.
A lot of old preset manual lens had a T Mount. This helped the stockists as they only had to stock the basic lens and then could sell the T mount Adapter to fit the various makes of camera.
Some Spotting scopes have this Screw thread on the top of the Eyepiece which means with a T mount/ To P K adapter and cheap extention tubes, (needed to get the correct focus), you can get a really long lens to fit your pentax.
Be careful with the Two different threads as they are easily stripped if fitted in the wrong place. Pentax/ Praktica M42 is 1mm pitch and T2 mount is 0.75 pitch.
Patty
Patty
Here,
there,
everywhere
My Website
flickr
G+
Facebook
