PSE9 & CS5 bit depth question 8bit / 16bit functions?
Posted 22/09/2011 - 22:02
mikeyscope wrote:
I've just been used to processing images from scanned transparencies which are 8bit scans. However having made the move to digital the files are now 16bit but some functions don't work in 16bit until converted to 8bit (cloning stamp for instance), is this simply the built in limited functionality of PSE9 which then work fully in CS5 as 16bit :
Thanks in advance...
Indeed it is, Mike. For earlier versions there were supposedly 'work arounds' available that would at least let one create 16-bit layers in Elements, but I could never get them to work. My policy now is to do most of the critical editing (WB, exposure, cloning/spot removal, contrast, hue and saturation) on a virtual copy of the .DNG (Adobe RGB) in LR and, where necessary, switch to 8-bit sRGB in PSE for anything else (usually just selective sharpening using layers and the high-pass filter and then resizing).I've just been used to processing images from scanned transparencies which are 8bit scans. However having made the move to digital the files are now 16bit but some functions don't work in 16bit until converted to 8bit (cloning stamp for instance), is this simply the built in limited functionality of PSE9 which then work fully in CS5 as 16bit :
Jon
Posted 23/09/2011 - 02:53
Jon
Thanks for the feedback...so put simply if I want these functions to work in 16bit I'm better upgrading to full Photoshop CS5.....yes??
Posted 24/09/2011 - 10:42
Many thanks to you both for confirming this, much appreciated!
Posted 24/09/2011 - 17:25
As a rank amateur when it comes to PP photos is there a noticeable difference in the finished quality of the photo between 8 and 16 bit format.
I use Lightroom to do all the initial adjustments to the photo and then export it as an 8bit Tiff for editing on Elements 9.
Greg
Greg
Posted 24/09/2011 - 17:32
Greg
You won't notice any difference unless you are doing something very specific and then you'll probably be doing some job of work.As a rank amateur when it comes to PP photos is there a noticeable difference in the finished quality of the photo between 8 and 16 bit format.
Greg
Everything depends on how much manipulation is being done and the final output size and purpose, but for normal use there's no problem with 8 bit.
I'll bet most users haven't even really noted that 16 bit is there.
Posted 24/09/2011 - 17:42
Thanks for clarifying John.
Greg
Greg
Lesmahagow,
South Lanarkshire
Sorry this question is probably obvious and sure most of you knew what was coming by the title alone but can't seem to find a simple answer in any of the related threads.
