Product photography set up.
Posted 24/11/2016 - 14:27 - Helpful Comment
As you already have a light tent, would it be better to look for a couple of desk lamps from a DIY chain such as Homebase or B & Q? Alternatively use natural light possibly with off camera fill in flash
Posted 24/11/2016 - 14:56 - Helpful Comment
You can buy all sorts of equipment to "improve" your results - but as the previous responder says - you've got the light tent so you can experiment with lamps, torches, off camera flash (if you have one), daylight etc.
Exposure times won't be a major issue if you use a tripod (turn off "Shake Reduction" though) - Backgrounds can be cobbled together from many sources (I've used the inner lining of a coat for a deep red, silky background) - cushions, clothing, etc.
Because it's digital it's only really time that's the cost - and it's a great way to gain some experience in another area.
Have fun
Have fun
Posted 24/11/2016 - 16:58 - Helpful Comment
My other half sells jewellery. I'm not involved with the day to day photography so can't claim credit for the photos on her website, buy I did help her to get started with the setup she uses for everything.
She uses a small light tent, and two charity shop desk lamps with daylight bulbs bought from Amazon. The equipment all in cost about £35 apart from her DSLR and tripod.
The lights are outside the tent at about 40° to the piece being photographed. Backgrounds are homemade, wood painted in artist's gesso.
As stated above, exposure times are meaningless providing you have a good tripod (my Slik, purchased long before digital cameras were a thing). She sets the white balance manually, then uses the self timer for long exposures with small apertures; her camera underexposes by default so she has to dial in one and a half stops or so to get nice colours.
She has a nice little business selling online and through a growing selection of shops. I hope you will forgive the link, but it shows the pictures and I am very proud!
https://folksy.com/shops/GwinKerry
Posted 24/11/2016 - 20:00
That's all great advice and has given me a bit of confidence to have a play in a new area.
Thanks for the detailed reply and link Chris, much appreciated.
Posted 25/11/2016 - 00:38
If you try using LED lighting, make sure the LED lights are full spectrum, otherwise you could end up with strange colour cast that are very difficult to correct.
Posted 25/11/2016 - 10:05
What lens would be suitable?
Posted 25/11/2016 - 12:46
Re a suitable lens, I normally use a 100mm macro for most of my still life work. But anything that fills the frame should suit
Posted 24/02/2017 - 19:26
davem wrote:
My daughter has started selling her Jewellery online. I was thinking of helping her by taking some good product photography sydney using a table light tent set up. What is the best way to do this? I don't need the best set up ever just something to get me started.
I have seen a set up here link
Its in the sale but by the time you have added VAT and delivery the cost is getting on for £60.
I have a large light tent I got off ebay very cheap a while ago.
Any thoughts?
Dave
Hello Dave,My daughter has started selling her Jewellery online. I was thinking of helping her by taking some good product photography sydney using a table light tent set up. What is the best way to do this? I don't need the best set up ever just something to get me started.
Any thoughts?
Dave
Can you please upload some new pictures that has been click by you????....
Posted 24/02/2017 - 19:53
They've certainly come out well but can I suggest something to give the items a sense of scale?
Posted 24/02/2017 - 21:49
Hi Dave
I would certainly use a lens of at least 100mm focal length, easier to isolate the subjects and get diffused backgrounds. Also, one that has smooth bokeh.
I wouldn't be afraid of using manual focus as it's immaterial on static subjects, you can use the Live View to get it 100% spot on. A lens I have that is very good for this type of work is an old one and can be bought cheaply - a 135mm SMC Takumar F3.5.
Macro lenses will also be good, one that has especially nice rendering and bokeh is the Sigma DG EX 105 Macro, again this can be bought quite cheaply second hand.
Hope this is helpful.
Posted 24/02/2017 - 22:32
Thanks David.
The photos came out ok using the 100mm DFA macro. But I need to get the white balance white as the background came you grey not the white of the material. Any suggestions?
Posted 24/02/2017 - 22:37
Hi Dave
The WB is easily fixed in post processing, you should have a white balance tool in whatever processing software you have? I use Adobe Camera RAW, just click on an area which should be white and it fixes the colour imbalance.
Posted 24/02/2017 - 23:36
Or (if you dont intend to post process, use a grey card in a test shot and adjust the white balance in camera before you do your product shots.
You will also have to overexpose the images. Under exposure will result in grey whites also.
20 years
yorkshire
Any thoughts?
Dave
