PROBLEMS WITH K 7
Posted 19/07/2010 - 14:34
Hello and welcome!
Sounds like a faulty camera, but try another card first just in case it's a faulty card. Always format the card in camera before first use, and every time afterwards that you clear the card.
Hope that helps!
Hope that helps!
Posted 19/07/2010 - 14:38
Sounds familiar. I hope it isn't the same problem, but try searching "vertical banding" on this forum. From my personal experience with my K20D my advice would be to get this camera replaced as rather than repaired if you can.
Posted 19/07/2010 - 14:44
That was a quick response to my topic, unfortunatly formating doesn't work, appears to be a faulty camera.
Thanks,
Bruce
Thanks,
Bruce
Posted 19/07/2010 - 15:11
It's a duff'un, send it back for replacement, not repair. Vertical banding has been an issue to varying degrees with just about every Pentax DSLR, and other makes also.
The problem is most pronounced in low light, longer shutter speed situations where you get some really dark areas in the frame. I try to avoid these situations as much as I can.
Posted 19/07/2010 - 15:52
I had the same problem with a K20, it just needed to have the firmware re-installed. In my case it showed up in bright light at 1/500 sec at f11
Posted 23/07/2010 - 17:03
Hope you solve the problem...anyway, welcome to the forum
Posted 22/08/2010 - 01:20
Hi and welcome to the forum.
Posted 22/08/2010 - 12:47
Thanks for everyones suggestions about my camera, and how the problem may be fixed.
Camera went back to suppliers, came back a week later.
I have taken abouut 700 shots since then and all the images so far have been perfect, the image quality is quite amazing.
Posted 22/08/2010 - 12:55
did they replace or repair the camera, do you know?
Barrie - Too Old To Die Young
Posted 22/08/2010 - 13:58
Welcome to the forum and I hope you get the camera problem resolved. Best of luck.
Stephen
Stephen
I gladly welcome C & C's. Being foggy minded they really help me learn.
Posted 23/08/2010 - 02:36
They repaired the camera, that's ok with me.
I also have a K10D, DA 18-250, Takumar 100 macro, Zeis 135
Posted 23/08/2010 - 08:27
G'day and welcome - now you can focus on taking pictures!
Purchased K 7 beginning of month, a lot of the images have very fine verticle lines, has anyone else had the same problem?
Camera is going back to suppliers later this week to be checked.
