problem with pentax k r
symi2
Posted 01/09/2011 - 12:20 Link
I am a new user to this camera & still learning.
Every time i try to take a single shot the shutter goes twice & then takes time to process the image (of which there is only one )
I have been trough all the menus but cannot find out how to fix this
bforbes
Posted 01/09/2011 - 12:38 Link
Check to see if the shutter is set to operate using the 2 sec. timer don't have a Kr but it's usually on one of the function buttons on the back of the camera.
fatspider
Posted 01/09/2011 - 13:18 Link
Its also possible you have it set to a slow shutter speed (or the camera is choosing one), the double exposure your hearing is probably the shutter opening and then closing after the time lag, that would also account for the image taking longer to process and be displayed on the LCD
My PPG link
My Flckr link
davey
Posted 01/09/2011 - 16:04 Link
In addition to the above:
Could it be you've got HDR switched on? That would take more than one shot - not sure how many though.
Could it be you've got multi exposure switched on?
Is it possible you've got drive set to hi speed - that would give fast shooting while you've got the shutter pressed - although you would get several shots.
One thing that caught me out and made the camera slow to display and save an image, was that I'd inadvertently switched Lens correction on. This really did slow things down.
Cheers, davey.
geordie01
Posted 01/09/2011 - 16:39 Link
Check 2 sec self timer off my, favourite to set by mistake
auto bracketing off
hdr off
live view not on as mirror will drop sounds like the shutter
set camera to default setting
Edited by geordie01: 01/09/2011 - 16:40
symi2
Posted 02/09/2011 - 14:01 Link
Many thanks to all for your help.
Checked everthing,turns out i had lens correction on.
Wont forget that one again
