Problem with Metz 58 AF-1
Posted 05/04/2008 - 21:55
Yesterday I received a replacement flash unit, and I'm pleased (and relieved) to report that it works a treat. Now to get to grips with P-TTL!
Enjoy the flash, it is great and I like the bounce flash effect.Yesterday I received a replacement flash unit, and I'm pleased (and relieved) to report that it works a treat. Now to get to grips with P-TTL!
p-TTL is very straightforward, all settings work from the camera, It only becomes complex when using flash to trigger a slave and then the pre-flash triggers the slave and it does not show in the picture.
I have been playing with the strobe setting!
Flash: Metz 58, Metz 48
Posted 09/04/2008 - 01:26
South East London
Also, when you change the zoom on your lens, is the flash head responding? What more is your camera set to and are you using a DA lens? Also, is you K10D on firware 1.3 - I don't know but this might make a difference.
Have you checked the base module of the flash to confirm it is a Pentax one?
Just some suggestions...
