Problem with extension tubes
Posted 11/05/2015 - 06:28
Guess:
Your extension tubes are non conducting (black paint or anodized); try to stick some foil between the tube and the camera body to sort the contacts.
Posted 11/05/2015 - 10:52
Hi Kris,
If as sterretje suggests it is due to the black paint than you might want to remove a section close to the contacts area. This is what I had to do with my Petri 28/2.0. The aluminium foil trick does work, but if it bunched up or rips you run the risk of little bits of foil inside your camera
Here's where I scraped on the back of the Petri:
Alternatively you could buy a set with contacts and modification from me - I'll do you a good price
Posted 12/05/2015 - 00:34
I had similar problems with black painted ones and, having scraped the paint off, it still didn't work so I tried some of that very expensive real silver paint - absolute waste of money - don't do it.
I had another set with full contacts that refused to work which had an extra pin (Richo style). I opened the base and removed it from each tube ( fiddly, awkward job) and hey - it now works! No idea why.
Hertfordshire,
mostly.
I have a set of AICO extension tubes which I have had for many years and have been used on my original MX, the K10D, the K20D... They don't have A-type contacts but do have the actuation lever so that setting the "allow use of aperture ring" setting works fine. I've often used them with lenses like my M100/2.8.
I've just been trying them with my K-3 and my K85/1.8. The aperture doesn't shut down when I take the shot. Yes, allow use of aperture ring is set to yes. Any clues as to the problem?
Thanks, Kris.
