problem changing flash output on K50
One thing, at least on the K7/K5 series, you don't actually have to select the flash compensation setting to adjust it ... As soon as the flash mode display appears you just turn the rear e-dial to make the adjustment. It may be that it's waiting for you to do something and just times out ... ?
When the flash mode disappears (and it does not happene very time) it goes back to the main screen. It only stays visible a couple of seconds. I have just tried it again and it is working perfectly. I wonder if sometimes the way I hold it when hurrying I may be touching the shutter button just enough have it revert. .
There is a ' memory' item in the menus for flash compensation that will remember the setting when the camera is switched off. This could be handy but for many situations the default of 0 compensation probably makes most sense.
10 years
