Prints with borders
Posted 24/11/2009 - 14:15
in PSE8 which is probably similar: window>content then select frames and choose one close to what you want and adjust from there.
Posted 25/11/2009 - 06:08
1)Open your image
2)Open new file and size the canvas about 35cm X 45cm
3)Use the moving tool and drag your image on top of the new canvas
4)Set your cropping tool to 20cm X 30cm and crop the image to your required border width
5)Flatten image
This works with CS3 but I am not to familiar with Elements 7. I hope however that I have pointed you in the right direction..
Pentax greetings
Imagesteve
5)Flatten image
Pentax greetings
Imagesteve
2x K10D bodies, 2x FA 28-200 3.8-5.6, DA 18-55, A 50 F2, 50mm Macro, 360 FGZ. Still saving for the 60-250 DA* Also have a Z10 35mm and a K1000 just for fun. IF PENTAX IS THE ANSWER, WHO CARES WHAT THE QUESTION IS...!
Posted 25/11/2009 - 06:17
I find the easiest way is to first select your image, then go to Image>Resize>Canvas size, then select the number of pixels/cms you want and the colour (at the bottom).
If you want to do say a thin black border followed by a thicker white one, you just do the same thing twice adjusting the size & colour accordingly.
Posted 25/11/2009 - 06:24
Makes a lot of sence Dr. I have tried it and it works quite well. That is indeed easier.
If you want to add a black border on my method, just repeat the process but use your paintbucket tool to colour the new canvas black.
Cheers!!
Cheers!!
Posted 25/11/2009 - 08:10
Select All (Ctrl+A) then Edit>Stroke and select how many pixels wide you want the line, what colour, etc.
When that's done Deselect All (Ctrl+D) and save as required.
Posted 25/11/2009 - 13:00
Thanks for the suggestions I wil try them out when I get home. When I am done if I resise the new bordered image to the exacxt size I want to print, am I right in thinking that it will print as I see it i.e with the border?
There are three kinds of people in this world, those that can count and those that can't
Posted 26/11/2009 - 18:41
What I am trying to say is this. After putting a border around my image using the resise canvas option and saving it, if then I resize the print to say 10x8 for printing would that include the border within those dimensions. I guess what I mean is would the border become part of the image or would it still be the canvas?
So sorry for any confusion.
Posted 26/11/2009 - 18:51
yes, that will work
Posted 27/11/2009 - 12:09
Is this the sort of thing? If so it's in the book "The photoshop elements 7 book for digital photographers by Kelby and Kloskowski" and is a breeze.
Hope it helps,
Andy
[IMG]http://img.photobucket.com/albums/v48/avarney/SRINGDROPS.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v48/avarney/LONDSALEA6CARD.jpg[/IMG]
Hope it helps,
Andy
It's not the size of the dog in the fight, but the size of the fight in the dog!
Inverness
