Printing tips, when buying in prints
dougf8
Posted 25/07/2012 - 11:41 Link
Stupid time
OK I'm printing bigger e.g. A3, A2 and sending away for prints.
How do I get the best results?
I've slaved over my RAW development, looked at every inch of the print and finally I upload it to a printer and then what?
How do I ensure that what I get back matches my sent image?
Do I resize for the paper? And what if their software decides to do something with my pixels, like resize them?
In other words, how do you ensure the returning print looks as close to what you intended as possible?
Lurking is shirking.!
Blythman
Posted 25/07/2012 - 11:53 - Helpful Comment Link
Calibrate your monitor
re-size print to pixel size required by lab and dpi required (off top of my head I do this in photoshop and tick the re-sample box when I'm re-sizing)
Use colour profile advised by lab (often srgb but sometimes have their own). Again, this can be done in photoshop.
The lab may have options for auto-correct or to print as is. Do not choose auto correct
May find this useful http://www.dscolourlabs.co.uk/tech_support.cfm
Alan
dougf8
Posted 25/07/2012 - 19:05 Link
Alan thanks
McGregNi
Posted 30/07/2012 - 22:51 - Helpful Comment Link
I've used numerous online printers (check out my post for the latest)link, and never had any issue with image size or resolution.
It seems that so long as there is enough data in the file for the size you are choosing to print, then the website software does all the dirty work and automatically creates the right output figures. Thats been my experience anyway. I have always used my maximum quality JPEGs to upload using the highest upload quality option (slowest). These files are usually around 5-10mb. This is exactly what I used for the FOTO.com poster prints I raved about in that earlier post, and there is no discernable loss in quality at all.
I don't think it will make any difference what resolution your files are - they will just be automatically adjusted to whatever the printing system requires for each particular print size.
womble
Posted 31/07/2012 - 11:39 - Helpful Comment Link
As long as there are enough pixels to do the job. I used to typeset academic books for a living and the arguments I had with authors about their 200 pixel wide images... "but it looks alright on screen!" Line drawings for publication normally need 1300dpi tiff files! Photographs, however, can be printed (generally) at a much lower resolution, but you still need enough pixels to do the job.
K.
McGregNi
Posted 31/07/2012 - 17:10 - Helpful Comment Link
Yes, K, I should have clarified that. When I ordered some mega sized prints recently on FOTO.com as I was choosing the print size I was seeing a comment on quality for each photo - eg. 'optimum', 'acceptable', 'reasonable'. As I wanted these big prints to be on the wall I made sure I ordered the maximum size I could get that maintained the 'optimum' rating.
The results speak for themselves as even the biggest 60cm by 90cm prints show no reduction in quality from the same shots printed at 12" by 8".
But what is significant is the very obvious difference between those photos shot with my K7 (14.5mp) and others on a digital compact (9mp). The maximum size at 'optimum' from the compact was 30cm by 40cm (still very impressive). I'm guessing that so long as the file is at least a few megapixels then theres enough data to produce quite good enlargements.
dougf8
Posted 31/07/2012 - 18:30 Link
The fear in my question is that a company that maps pixels onto paper, you will need to resize and put in borders etc ... harder for the average punter.
If they resize you are at the mercy of their resizing routine and do they crop, or shrink or change ratios.
4000x3000 pixels gets you 13" x 10", at 300 dpi, a bit more needed for A2, so somebody needs to resize. If I do it, and I'm a few pixels out for whatever reason, they will then resize again .... however at A2 my nose is not going to be pressed against the paper so should I worry.... no probably not.
Jessops were good as I could choose the crop, photobox it seems a little more fire and forget.
Also a printing person and PhotoShop guru suggested that if resizing bigger, then do it about 5% at a time repeatedly, to get better quality results. I haven't tested that yet.
I'll try DSCL next
Pentaxophile
Posted 31/07/2012 - 18:48 - Helpful Comment Link
If 4000x3000 gets you 13" x 10", and you print at A2, all that will happen is your print will be a bit less than 300 pixels to each inch. *Personally* I wouldn't worry too much about the output dropping to about 200 pixels per inch, because you tend to back off in any case. YMMV.
You can end up chasing your tail with this stuff...
Edited by Pentaxophile: 31/07/2012 - 19:17
Posted 31/07/2012 - 18:54 - Helpful Comment Link
The extra pixels needed to maintain 300ppi are creted in Photoshop by resampling the image.
Bicubic is very satisfactory and for greater refinement in more extreme size changes, bicubic smoother to upsize and bicubic sharper to downsize. You might want to downsize for the web and this will keep your image looking sharp.
McGregNi
Posted 31/07/2012 - 20:41 - Helpful Comment Link
I don't think these questions are important unless you are outputting to your own printer - then yes, you have to worry about filling up your sheets of paper. For online printing, the company will have their range of standard sizes which you choose for each photo. Firstly you go for the one that most closely matches your desired size and the aspect ratio of your shot.
Once the photo is uploaded and you've selected the print size you should see a thumbnail of your photo with a border around - this represents any small differences between the dimensions of your image and the sheet of paper. So long as your images have not been resized (in Photoshop for example) to an unconventional width/height/length, then the border should closely match your image.
Bear in mind that our cameras produce a photo of a standard dimension (and resolution). Because I don't print my own photos I don't even think about this - I don't need to know.
When the images are opened in an editing program they retain the dimensions and resolution that the camera output unless you change it. You will have conventional sized photos which should fit into most standard print companies choice of print sizes.
If you choose a print size that is slightly different , then you'll see from the border markings whether it's going outside the edges or it's within the border. You usually get a choice (a drop down arrow) to decide whether to have the photo cropped to fit the border, or to be resized to fill the sheet of paper.
I know this does remove the final ultimate control over the exact edges of your shot, but it makes it very simple! Its probably best to allow a little extra space on the important edges when cropping in an editor in case you lose a bit when its printed.
dougf8
Posted 31/07/2012 - 23:00 Link
If I can squeeze a little more crispness out of a print by having a think about this then it's not a waste. I can't afford an A2 (or bigger) printer so buying in is the only option.
I understand the process of resizing and re-sampling, but the tip I had was to perform this in stages. Rather than increasing the size of an image by 100% in one hop, I have it on good authority (untested as yet) that to perform this in a series of smaller steps, results in a superior image.
Admitedly, a 100% increase is only an extra pixel between two others, so hardly a tough ask, but I suppose it might make a difference on a bigger stretch. Anyway a bit of homework will reveal.
Edited by dougf8: 31/07/2012 - 23:00
Posted 31/07/2012 - 23:28 - Helpful Comment Link
This used to be the case, but is no longer necessary. Photoshop or Genuine Fractals will do the job in one step. Not all other programs may do as good a job, but of course it can be tested by trying it out.
arto
Posted 02/08/2012 - 10:05 - Helpful Comment Link
My advice to customers is to supply the image at its native size. We resize on the fly (ie at the point of printing) using far better resampling algorithims than PS can offer. As long as your image is in the region of 240ppi minimum at the required size (do the maths or use PS's Image Resize with Resample unchecked) you will get a nice result. Even 180ppi can be OK for larger prints under some circumstances.
As for colour, make sure you tag your image with a decent colour space - sRGB may be acceptable at some printers, but at the Siskin Press we print a wider gamut than sRGB, so we recommend AdobeRGB or ProPhotoRGB. Your image may already be tagged in camera, otherwise use Assign Profile in PS. From then on, any changes in profile (eg to a profile offered by your print provider) should be made using Convert to Profile to prevent colour shifts.
If in doubt, talk to your printer (assuming there is a human there) and yes, as mentioned earlier, do make sure your monitor is calibrated, and, importantly, that the brightness is set to around 100-120cd/m2, otherwise you will get dark prints.
To be clear, this is just how we work at the Siskin Press - other print providers with more automated systems may do things differently.
Posted 02/08/2012 - 10:18 Link
To be fair, we can get away very nicely with a bit of leeway, but for optimum results providing the printer/publisher/website with exactly what their specification asks for is always a good idea.
It's the same as the exortation to read the rules in competitions.
simonkit
Posted 02/08/2012 - 23:31 - Helpful Comment Link
Ref resizing there are differing opinions vs the "one shot" or stepped approach...I read quite recently (unfortunately can't remember where) that the small step approach using 10% is still best so have a Photoshop action for this - having said this I didn't really have any issue with bicubic smoother.
I find the best way to ensure you get back what you intended is to crop/resize your image to exactly the print size you require, do all editing yourself and then make sure the printer doesn't do anything to your file other than print it.
Most problems people seem to have relate to incorrect colorspace (normally they've used ARGB instead of SRGB)and failing to make sure they sized their image correctly
Simon
