Portrait and Glamour Shots.
Posted 11/08/2008 - 23:22
Need any helpers ??
Posted 11/08/2008 - 23:43
Making these images good will be quite a challenge if you haven't done this sort of photography before.
I would recommend lots of portrait practice before the first proper shoot and make sure you are totally familiar with both camera kit and lighting.
The 70-300mm lens is very long and not necessarily the best place to start. The standard 18-55mm lens at its longest end is an ideal portrait lens.
As regards the lighting, keep it simple, one main light, one fill in and maybe a snoot to catch the hair. Simple backgrounds are good (I like black, but white is the in thing).
As regards the model don't forget to talk to her and guide her. Pay attention to detail and make the session fun.
There are lots of books on portrait and glamour and these are really essential reading.
Hope that helps a little at least.
Posted 11/08/2008 - 23:47
set your lens to 85 or 100 mm, and don't use the zoom, or you'll have exposure problems.
that looks to be an ok starter kit.
the only advice I'd offer is this:
the pentax 360, and 540 flash units with stands and umbrellas (1 silver, 1 white, and two shoot through) with stands will serve just as well, and be be more versitile, overall.
if you want pro lights, buy pro, the bottom of the line mono/studio lights don't have the build to stand up to rugged use, seldom have the range of accessories you may want, and often lack the control over output a pro might want.
(kinda like buying an El Camino. (link) Part car, part truck, sounds great at first, till you realize you got the load capacity of a car, with the passenger room of a truck....the worst of both worlds!)
Posted 11/08/2008 - 23:50
Cheers John,
do you think that light kit is a worthwhile investment?
interesting comment on the kit lens , i hadnt thought of that as the little bit of reading ive done so far is pointing towards the longer lens can you advise me please?
I know you cant say exactly but with the lighting tips you advise and the kit lens what kind of aperture and shutter speeds would you employ ( tripod mounted ).
Posted 11/08/2008 - 23:54
Thanks Don ,
Ill have to experiment with both lenses i reckon .
For the time being ill be offering my services for free and when i gather more experience i will slowly start charging a nominal fee to assist in the purchase of better lights as ive seen they dont come cheap!
Posted 12/08/2008 - 00:00
The Portaflash kit is basic, not incredibly well made, but serviceable. We use one at the camera club because it's realistic that members might buy such a kit. The results will be just as good as with anything else if used well and it does contain everything you need to start with. The price is very affordable.
The shutter speed I set maually to 1/180 second and the aperture will be around f8 in all probablility. You can check your exposure with your camera screen and the histogram, so a flash meter you can survive without.
To make life easier purchase of an Infra Red trigger will be much better than using synch cables and this I would get straight away. No cable to trip over!
The kit lens at 50mm - 55mm is around the equivalent of 75-80mm on a film SLR, which is very close to the classic 85mm portrait lens. You will also be able to focus closer than with the 70-300mm which is really far too long for a small studio setting.
And finally, with flash you will not need a tripod as the flash exposures will be very short and camera shake will not be a problem. So for most shots ditch the tripod and be creative and free without it.
Don't forget to experiment and practice before the first real live shoot.
Posted 12/08/2008 - 00:08
Cheers John,
You certainly know your stuff , i think youve covered most of my questions, good to hear youve experience with the actual light kit and thats what ill go for first i think.
Do you have any examples of portrait/glamour youve taken with similar kit as then i know what ive got to aim for!
Just need to get the wallet out and get spending.
Cheers.
Cheers.
Posted 12/08/2008 - 00:12
yeah, you'll have to experiment.
I'm big on using longer focal lengths, when you can.
I get giddy when I can put at least ten feet between my subject and the backdrop, then back up with a 100mm lens to get ther shot. Not always doable.
The zoom comment has to do with using variable aperture zooms, with manual strobes. the same rule applys to the kit lens. If you change the zoom, you'll need to re-check your exposure settings to compensate.
Posted 12/08/2008 - 00:16
Apologies for asking don , but im interested in your favouritism towards longer focal lengths what are the benefits when shooting this style of photography?
Posted 12/08/2008 - 00:32
compression of feild effect...
makes a big nose look small.
wide angles work great for anorexic stick girls, with pretty features, and also for profile shots...
but longer lenses help average people look better.....
link
here's an example of compression of field effect...
the little cabin is about two football fields behind the subject. had I shot with a wide angle, the building would be tiny in the frame, and the road, trees and old fort would all be in the scene as well.
link
Posted 12/08/2008 - 07:51
An example using Portaflash:
[IMG]http://i240.photobucket.com/albums/ff250/johnriley1uk/032-Emma-1.jpg[/IMG]
Posted 12/08/2008 - 09:12
Longer lenses (over 75mm on digital) are fine for tight portraits (head, or head and shoulders if you have a big enough studio), but they are no good for glamour, which involves more than just head and shoulders.
As well as being kind to today's fuller figures and faces (as Don mentioned), longer lenses are quite good for new models because the 'tog' can work further away. The model won't feel so crowded.
But for your purposes, the standard lens will be fine. If you can find a second-hand SMC-P 24-70 1:4, you will be able to zoom without upsetting exposure. But these lenses, though optically excellent, can suffer from element separation, so buy carefully.
The problem with cheap lights (apart from unreliability, shoddy construction, low output, and long recycling times) is that they generally offer much less control over light output.
In your shoes I would attempt to buy good second-hand lights (like Bowens) rather than cheap Portaflash units. (I speak from experience, having owned three of different sizes.)
If you can't stretch to that, then the Pentax 540 flashguns can generally be had for around £50 or so on Ebay, and work fine in manual mode with diffusers of some sort or another. They offer great control over light output and in fact are similar to the Nikon units recommended by Strobist. They are much easier to carry around, too.
http://strobist.blogspot.com/
Forget P-TTL and TTL. In the studio, manual gives greater control.
Kent
I have a variety of girls that would like me to do some portrait and glamour shots for them .
Ill be using my k10 and the tamron 70-300mm lens i have.
A friend has said he has this light set he can let me have for a good price - do u think its any good ? or would i need extra lights?
I was trying to find information on the lens and apparently the sweet spot is around f8 just wondered how that would relate to taking photos with these lights and zoomed in but not to the full 300mm in a stuidio.
Any help or advice would be greatly appreciated!
cheers.
