Poorly Pentax K-1 (full frame)
If you haven't tried it yet, put a fully charged main battery in the camera, turn the camera on, set time and date, change settings so that the camera will remain on and not enter sleep mode, then leave it on for many hours (overnight?). It might just manage to get a bit of charge into whatever isn't working. But don't hold your breath.
Good luck.
This sort of thing is fairly common with other cameras, too. Batteries and capacitors eventually die and leaving a camera unused for a long while doesn't do them any favours. The Ricoh website says that date and time will be retained for 48 hrs max after the main battery has been removed. So if your main battery drained while you weren't using the camera, or it wasn't in the camera, the internal battery (or capacitor?) will have run down until it was completely discharged. Not a good situation.
Good luck.
I'll let you know if it works!
Luisella
If the main battery goes flat, the clock battery will in time go flat too, and in time reach the stage where it isn't rechargeable.
On the first Pentax DSLRs the clock battery was replaceable, but on later ones they are hard-wired for cost saving reasons, and I imagine that other brands are the same.
If you are an electronic whizz-kid with superior soldering skills you might be able to de-solder the clock battery and replace it. But that's a big if.
I stopped shooting for quite a while and now have two K10D's and one K20D with the same problem. Over the winter I might strip down one of the 10's and see if a repair might in any way be feasible.
My K-01has needed the clock to be set whenever I change battery ... so long as it has a charged battery it seems to keep the clock going.
I have just tried it after not using it for some while and it shows the correct date and time.
Certainly the setting persists while the camera is off as I've just tested.
The internal battery must be on its last legs. I guess the only solution is to keep charged batteries in the camera.
As for the date/time battery, discharging a lithium ion battery to a low level causes physical and chemical changes to its internals which reduces it's ability to hold charge and its performance while discharging. The changes depend on the charge/discharge history and environmental factors (temperature etc.). Once the damage is done, it can't be undone. Usual advice is not to let its charge drop below 20%. That shouldn't be a problem with the main battery as there should still be enough charge in the battery when the camera says 'battery depleted'. However, the date/time battery does not appear to be monitored so it's best to keep a charged main battery in the camera to avoid a deep discharge.
Thank you again for the help
Luisella
it still asks me date and time when I switch on. BUT... If I just ignore the request (press menu and it goes), the camera knows the correct time and date! If I push Info, it gives me the correct time/date, as entered earlier on.
Electronic cameras, like computers, watches, and other gizmos, can only "remember" the time and other ephemeral data if there is a battery inside it that isn't flat. Since the main battery has to be taken out of the device from time to time all these machines have another battery inside to keep the memory functioning. On computers they are often called the CMOS battery or the clock battery.
Another problem with the K 1 is the weather sealing. After you open the camera and repair the battery, the camera is not sealed anymore.
I am getting a couples of new batteries, and I will make sure that there is always a charged one in the camera. I also need to try to use the camera sometimes....
hemel hempstead
I contacted SRS and they told me it is impossible to change the internal battery
The only options are:
1) live with it
2) buy a new camera.
Has anyone seen the same problem? Even better, has anyone got a solution?
Luisella
