Polarising filter with DA*16-50
Posted 14/07/2009 - 11:02
I believe Hoya do an ultra thin one.Hoya Pro 1 D may thin enough also.A bit costly though. I picked up a Pro 1 D Circ Pol from Camera world for £52,cheapest I could find for a 67mm filter.HTH a little bit,
mm
mm
Posted 14/07/2009 - 11:21
Hoya Pro 1 D gets my vote too...decent quality, no vignetting (on my 17-70 anyway
simon
simon
Find me on Google+ link
Posted 14/07/2009 - 12:49
I read an online comparison of polarising filters last week. Not scientific but seemed objective enough. Can't remember the link.
Anyway, the conclusion was that cheap polarisers with little or no coatings added a whole lot of flare and reflections to images in certain situations. They recommended B+W - which aren't cheap - and also said the Hoya Pro were pretty good. Interestingly they also wrote that the previous range of Hoyas, I think designated HMC and SHMC: were better performers than the latest range.
@pschlute: you're right the Pro range are not cheap but you've invested a lot of money in a great lens. If you believe the recommendations and my third-hand account of a test, why waste your lens investment by saving £50 on a filter?
I'm just a beginner but I read in a lot of places to invest in lenses, not camera bodies. You could think of the filters as an extension to the lens. I started a similar thread a while ago, lots of good advice from members. I eventually chose to get dedicated filters rather than a system and to wait longer before purchasing but to buy better quality.
K20D | DA*16-50 | DA*50-135
MacBook Pro | Dell U2410 Monitor | Wacom Tablet
Posted 14/07/2009 - 13:26
mpjx
Thanks for that. I quite agree that if I am going to put anything in front of the lens it will be the best quality I can get. I don't use any filters (uv ; skylight)normally on the lenses I own. The polariser is a one off purchase so it is worth going for the best.
Posted 14/07/2009 - 13:36
pschlute wrote:
Ouch the Pro 1 D Circ Pol 77mm is not cheap !
£72 AT Camera world.You can probably find cheaper.Ouch the Pro 1 D Circ Pol 77mm is not cheap !
Regards mm
Posted 14/07/2009 - 15:22
missmarple wrote:
Regards mm
Thanks for that missmarple. Well detected
Regards mm
Posted 14/07/2009 - 16:30
The price at SRS has gone up significantly recently - so the others will probably follow soon.
I would go for the Pro 1 D - get the 77mm and if you have a DA*50-135 get a 77-67 step ring so it can be used there too.
I am not suggesting that the ones at CameraWorld are not Hoya, but there were a lot of fake ones around a few months back and there may be a thread about it.
Posted 14/07/2009 - 16:37
@polchraine: Thanks for the info. Do you know if it is possible to fit/use the lens hood on the DA*50-135 if a 77-67mm step ring is used? I've taken a look - it seems it may be possible but I think the hood will have to be fitted before the filter and cannot be removed until after the filter is removed. Am I right?I would go for the Pro 1 D - get the 77mm and if you have a DA*50-135 get a 77-67 step ring so it can be used there too.
Any tips for spotting a fake or questions to ask a retailer?
Posted 14/07/2009 - 17:02
I don't have a polarising here (borrowed!) but have tried with a standard 77mm protector with no step ring and my DA*50-135 and it will fit inside the lens hood - just, so it will need some fiddling to get it in place once the hood is on and use a 77mm lens cap to grip. I don't think it could be done before fitting the hood.
As for fakes - no real idea, but ask the retailer - what will he say!
I am fortunate - I have a 67mm Pro1 (not D) from my 24-90 lens which now sits on the *istD.
Posted 14/07/2009 - 17:12
@Polchraine: That's what I thought. I can see myself getting very frustrated with the fiddling, especially in the rain in winter... I guess it's always possible shoot the 50-135 without the hood - until I can afford a 67mm filter also.I don't have a polarising here (borrowed!) but have tried with a standard 77mm protector with no step ring and my DA*50-135 and it will fit inside the lens hood - just, so it will need some fiddling to get it in place once the hood is on and use a 77mm lens cap to grip. I don't think it could be done before fitting the hood.
He say NO!As for fakes - no real idea, but ask the retailer - what will he say!
Actually, I think it is another argument for buying from a reputable dealer like SRS or my local camera shop. I imagine the fakes are most likely to turn up on eBay, Amazon, etc?
Posted 14/07/2009 - 17:17
I must apologise for the link below as it is a Canon site ...
but have a read through ...
http://photography-on-the.net/forum/showthread.php?t=672712
Posted 14/07/2009 - 17:19
Just seen your last post ...
An step ring will cost £10 of so. A little negotiation with a retailer for 2 small but expensive items could bring the prices down a little so think about getting both now.
20 years
Surrey
Will I need an ultra thin one to avoid vignetting ?
