Playing with ICM and normal landscapes
Posted 25/06/2021 - 22:39 - Helpful Comment
These are really cool Gareth (and coincidentally in sync with my more recent experimenting). I just love that 'edge of reality' feeling that emanates from your set - beautifully done.
Posted 25/06/2021 - 23:30 - Helpful Comment
In my limited experience Gareth I've found it works better if you take the IS off.
Posted 27/06/2021 - 11:34 - Helpful Comment
As Karlo has suggested the use of IS has probably worked against you here - with it off the effect may have been a little more fluid. Some of these are "nearly but not quite" for me - no.10 being so close, if the movement in the grasses of the foreground had been more pronounced I think it would have been a better final image.
Sorry if I sound a bit harsh - but it is meant constructively (and is just my opinion)
Posted 28/06/2021 - 20:46
Thanks all. Lenny, not harsh but true. It's something that I'll revisit. I think I confused people when I said ICM! When I said ICM I meant in camera movement so keeping the camera stationary and awaiting the wind to move the grasses and capture that with a slow shutter speed. Clearly this isn't ICM and moving the camera mid exposure so I haven't explained it properly With no ND filter so just stopping the lens all the way down, I was handholding at 1/13th which isn't giving a lot of time to capture that movement but on some has, albeit subtle!
Appreciate the comments
11 years
Barrybados
1.
Pentax K1 & D FA 24-70mm by Gareth Williams, on Flickr
2. Slightly different angle
3.
4.
5.
6.
7.
8.
9.
10.
11.
