Photoshop problem
aliengrove
Posted 08/09/2010 - 11:55 Link
Photoshop keeps turning my computer off, especially when using any plug-ins. the last time was when opening a file from Bridge. Does anyone have any ideas what might be causing this, and how to fix it?? It's getting very annoying.
Jon.
terje-l
Posted 08/09/2010 - 12:10 Link
Sounds like a re-installation of Photoshop is in order.
Btw, is this Elements or full-blown Photoshop? And do you have enough RAM in your machine? Could also be a RAM fault.
Terry
aliengrove
Posted 08/09/2010 - 12:13 Link
I've just upgraded from CS4 to CS5 and it's still doing it. I have 3gb of RAM which as far as I can tell should be enough.
terje-l
Posted 08/09/2010 - 12:17 Link
Yes, I agree that 3 GByte RAM is OK. But you could have a faulty memory block within those 3 GByte.
I would try to a) run a memory check or b) swap the memory cards one by one to see if one of them is faulty.
Terry
aliengrove
Posted 08/09/2010 - 12:21 Link
OK yhanks, how do I run a memory check?
aliengrove
Posted 08/09/2010 - 12:55 Link
I've just run Windows memory diagnostics tool and it found no errors. Anyone any other ideas?
greynolds999
Posted 08/09/2010 - 13:03 Link
Are you using a laptop or a desktop? CS5 is very graphics intensive which can cause your computer to overheat and will turn itself off for safety.
Is your fan working and is it noisy? That could indicate a high temperature.
Or if your fan is quiet it could be broken.
Edited by greynolds999: 08/09/2010 - 13:07
aliengrove
Posted 08/09/2010 - 13:39 Link
I'm using a laptop, so that might make sense. The fan seems to be working ok and is not noisy, but the compuer does seem to get very hot sometimes. I might try getting one of those lapttop stands with a fan in them and see if it improves things. Thanks for the reply!
terje-l
Posted 08/09/2010 - 15:45 Link
I have seen computers that run memory checks quite happily, but there is still a memory fault present. The only way to check is really to replace one module at a time and try the application again.
Terry
aliengrove
Posted 08/09/2010 - 16:24 Link
Thanks Terry I will give that a go and see if that works.
greynolds999
Posted 08/09/2010 - 17:19 Link
In terms of heat, if I'm running a batch process I tend to leave the laptop overhanging the desk with the vent clear.
If you're feeling brave you could try cleaning the vent which may help (but I take no repsonsibility for any damage).
Do you know if you're running 64 bit Windows as this will increase the power in use?
There is a program (do a search for it) called MobileMeter which can monitor the laptop's temperature.
Edited by greynolds999: 08/09/2010 - 17:23
aliengrove
Posted 08/09/2010 - 17:53 Link
Thanks Gareth I will have a look for that, meanwhile just mansged a few files without it switching off by leaving the vent uncovered on my lap! I'm running 32 bit, but it does seem to get a bit hot sometimes!
