Photobucket advice
Frogherder
Posted 02/07/2011 - 18:33 Link
Hi Guys,
On the upload page of Photobucket there is a note:-
Tip: Hold down CTRL to select multiple files
No matter what I do I can only ever upload 1 file at a time - am I missing something?
regards
Bernard
Posted 02/07/2011 - 18:47 Link
When you select the files you can use Shift and click on the first and last file in a sequence. If you use Ctrl and hold the key down you can select any number of files, whether they are in sequence or not.
Frogherder
Posted 02/07/2011 - 18:51 Link
Hi John,
That's what I expected to happen (just like the copy/paste function in windows explorer) but when I select a file - press/hold CTRL - move to another file select 2nd then 1st is unselected and so on. I finish up withjust one file - the last one selected.
regards
Bernard
Posted 02/07/2011 - 18:58 Link
A mystery then I'm afraid. It does work for me, so what is different I can't guess. I'm using Windows 7 and IE8 so maybe you could look at your system and browser and see if there's something there that's causing the problem?
greynolds999
Posted 02/07/2011 - 19:27 Link
This is a Windows setting. What OS are you using and are you using a touchscreen?
i-Berg
Posted 03/07/2011 - 00:51 Link
Have you tried ctrl-click using your other ctrl key as an alternative, on the off-chance one of them is dead?
Also, does shift-click work?
Frogherder
Posted 03/07/2011 - 15:19 Link
My operating system is XP + IE8.
Bog Standard Desktop Tower PC + LCD screen
I can transfer files from one folder to another on my PC using either CTRL key.
Ctrl-Click
Shift-click
Alt-click
Shift+CTRL-click
Shift+Alt-click
Shift+Alt+CTRL-click
Ctrl+ALT-click
all produce the same negative result, but do as expected when moving/copying files on the PC
Bernard
Gwyn
Posted 03/07/2011 - 20:59 Link
Bernard - just tried it and it didn't work for me either. Maybe the bulk uploader works, I haven't tried that. You need Java for it.
Edit: I can't even get the bulk uploader to work . Ah well.
Edited by Gwyn: 03/07/2011 - 21:03
greynolds999
Posted 03/07/2011 - 21:38 Link
I'm baffled. It may be that PB are not supporting XP properly any more?
Gwyn
Posted 03/07/2011 - 21:46 Link
I use W7 though. It seems to be a bug in Photobucket since there last update.
When and if I can raise the enthusiasm I shall send them a mail about it.
Supamag
Posted 03/07/2011 - 21:47 Link
I just tried it and could upload OK, I am using Firefox as my browser not IE maybe that has something to do with it?
Paul
Nil Satis Nisi Optimum
Paul
K-R 18-55 Kit lens & Tamron 70-300
dougf8
Posted 03/07/2011 - 21:51 Link
I use firefox and the upload progress disappears.
I just swap to Chrome to upload.
Lurking is shirking.!
Gwyn
Posted 03/07/2011 - 22:01 Link
I use Firefox and the upload progress disappears, and the ctrl multiple upload doesn't work either, not does the bulk uploader.
I don't have any other browser loaded, and don't really want to load another one, especially not Chrome.
Frogherder
Posted 03/07/2011 - 22:20 Link
Haha the plot thickens, at least I'm not alone.
I've sent an email to Photobucket technical help as it seems a bit daft to offer a "tip" which fails.
I'll keep you posted
Bernard
Frogherder
Posted 07/07/2011 - 19:22 Link
Update .....
Photobucket unable to advise as the link does work correctly - therefore it's my PC
I've checked my sons PC and this works as expected.
Now here's the odd thing.... My PC is identical to his except I have 80GB drive (his 40GB). Both run XP and IE8 and Outlook Express 6
I've now discovered that adding more than file as an attachment, which works on his (i'm sure it used to work on mine) is not possible in Outlook Express.
In view of the fact there are a number of programmes that this trait manifests it self I suspect there is a common box somewhere which is ticked (or not ticked). Does anyone know where I might find it?
Bernard
