Pentax/Tamron 18-250
Lilly
Posted 19/06/2009 - 00:39 Link
I am confused...
I am now thinking (instead of blowing 375 on the 21mm) that I should get a Pentax f3.5 18-250, but have read previous posts that say the Pentax 18-250mm (which only seems available now on Amazon) is the same as the Tamron 18-250mm F3.5-6.3 Di II LD Aspherical (IF) Macro - Pentax Fit.
Is this true are they the same lens? Plus SRS have the Tamron which is where I always preder to buy from.
Then there are the Sigmas to contend with, why is life so full of choices!
Is the Tamron the one to go for do you think, my gut feeling is yes?
Lilly
website
BLOG
FLICKR
hefty1
Posted 19/06/2009 - 00:48 Link
The Tamron and the Pentax are essentially the same except for the coatings; the Pentax has the SMC coatings and the Tamron has its own version. I don't use any of these "superzooms" personally so I've no idea which is the best I'm afraid...
Having said that, I do use some Limiteds and I know which I'd be happier spending my money on (*hint* it's not the zoom )
Joining the Q
Lilly
Posted 19/06/2009 - 00:52 Link
Yes, I do know what you mean Hefty, thats my problem, however I am going on a Documentary course soon and I seem to do a lot of DOC now and thought it more a priority than a prime with just 21mms.
website
BLOG
FLICKR
hefty1
Posted 19/06/2009 - 00:57 Link
But you've already got the 28-200, alright it's not quite as wide or as long at the ends but it's not a million miles away (or a couple of steps back and forward to be more accurate). Each to their own though and you know your needs better than I...
Joining the Q
gartmore
Posted 19/06/2009 - 07:28 Link
The vast majority of great documantary photography was taken with a 50mm lens on 35mm film
I'd go for the Sigma 30mm 1.4!
Posted 19/06/2009 - 10:17 Link
The Pentax 18-250mm is a very respectablew lens, but slow at the long end (f6.3) and quite bulky and heavy.
ericp
Posted 19/06/2009 - 10:40 Link
I have the Tamron version and it is my most used lens at the moment. It is very good and it is the same as the Pentax version except for the coating.
I have just bought the Pentax 16-50 2.8 and I will probably use that more now because of the speed (and lack of noise :lol but I will definitely miss the telephoto.
https://www.flickr.com/photos/_cypher/
Pentax K10D, 50, 18-55, 28-70, 100, Sigma 10-20, Tamron 18-250, 28-75
greynolds999
Posted 19/06/2009 - 10:50 Link
I have the Tamron which I use for those times I want to be discreet or when carrying a bag full of lenses isn't practical. It's a good enough lens, a little flat in bright light but pretty sharp. It is, as John says, slow at the long end (but you won't be down there much). It is a compromise as any superzoom will be, but considering the range it's pretty decent.
I do find with any lens like this it is the wide end you appreciate most which is why you may prefer it over your 28-200.
stevejcoe
Posted 19/06/2009 - 10:54 Link
I am with Hefty, you already have the 28-200 and the wide end is covered by the 10-20.
Have you considered the FA 35 F2? It is still available if you shop around and is a very good for use as a standard lens.
Also remember the 18-250 does not have quick shift.
Edited by stevejcoe: 19/06/2009 - 10:54
