Pentax Remote Control F
vic cross
Posted 16/01/2015 - 20:27 Link
CIF. K3 page 26. Prog. C4.
CIF. K5iis. page117.
Basically you set it up in the correct prog. mode with it focussed on a spot then you press the shutter and the camera will fire when something comes into focus. "SIMPLE"
As I used to tell the people I taught to use machine tools. IF ALL ELSE FAILS READ THE BL**DY MANUAL.
Hope that helps. CHEERS Vic.
50mpCMOS
Posted 16/01/2015 - 21:01 Link
About remotes:
1 First of all there would be the ideal range for something that is out of the box.
But...
If one were to slightly modify either (or perhaps both) the transmitter and/or receiver. One could easily get considerably better distance. Let me also clearly point out that I would strongly NOT suggest that anyone ever take a Pentax camera body apart. Doing so would completely void the warranty, would most likely damage items that area sealed (even weather sealed), and could easily damage the camera body beyond practical repair.
If one happens to know someone knowledgeable in electronics (especially fabrication) one could add to the receiver lens on the camera body and also do all kinds of tear apart work on the transmitter. There are all kinds of Nikon people who do this all of the time.
I've seen distances only limited by line of site, or some rare instance of bouncing a signal - well over several hundred meters.
There's also the art of purposely making a man in the middle type of device for the remote. Think of it as grabbing the signal, and then rebroadcasting it.
Anyone knowledgeable with items such as "pineapple transmitter/receiver" should be able to easily configure such a device. One could also pose the question and/or topic to a HAK5 Forum
Algernon
Posted 16/01/2015 - 21:32 Link
The Yonguo RF-602's will work at over 100M or you could set one at 100mm and relay it another 100M.
There are also IR jobbies that will cover over 100M for shutter release. (Acculine).
There's a later version of the Commlites I mentioned with 120M range link
I have some Wein IR gear that will cover over 500M.
Absolutely no need to modify anything or BS about it .
Edited by Algernon: 16/01/2015 - 21:33
