Pentax Remote Assistant...
Posted 01/05/2007 - 15:55
Nope, you did not miss anything. That is not an option.
Posted 01/05/2007 - 16:02
on the mac, you can drop it into a smart folder and use iether applescript or automator to rename, copy, move, resize, backup or even process with other apps automattically. (Any combination of the above is possible).
you could even drop it into Idisk and have it ready to share on the net.
Posted 01/05/2007 - 17:02
Thanks for the reply - even if it's not what I wanted to hear...
Don - Have already started writing a script to simulate that function on my PC (somewhat of an experiment - more used to mainframes than PC's)... Sounds like I need to take another look at a Mac - it's been about 10 years since I last looked...
MZ-6,K10D,K20D,Grip,DA*Zooms,DA 18-55-200 Kit,FA50,1.7TC,AFZ360
For Saleentax FA28-90,FA100-300,Sigma EX28-80,DC18-200,
Makinon 500mm Mirror
Posted 02/05/2007 - 12:49
ive just installed firmare 1.20 on my K10 and downloaded remote assistant but i seem to have a problem. I see nothing but i white screen in the window on my desktop. If i change a setting on the desktop it changes on the camera,dust removal works via the desktop etc etc. It will even release the shutter but takes no picture.
Any ideas??
Any ideas??
Posted 02/05/2007 - 13:13
When you power on your K10D and hold Menu, does it say that the firmware is in fact 1.20? (i.e. did it update properly?) I suspect this is OK, for me the K10D was not even detected until the firmware was upgraded.
When the shutter is released, does the green progress bar in the lower right of remote assistant show the image being transfered at all?
How about no the camera, does the LCD show the image or are images stored on the camera? Or are they stored on the hard drive anyway?
Try using the camera's shutter release button. Does it have the same effect? (It should work the same either via the computer or via the camera when connected).
Posted 02/05/2007 - 13:40
after some messing around ive got it working,the only thing i did different was download it from the us site and not the jp site,not sure if this made the differance but its working now
Posted 02/05/2007 - 21:29
Did you reboot after installing Remote Assistant? Wouldn't be windoze with out a reboot here and there!
Posted 02/05/2007 - 22:22
The new remote assistant has the same problem as the *istD one, it does not like being plugged into certain USB hubs (unpowwred ?). I had all sorts of problem with the D until I figured it out, it would not work with the USB hub I had (unpowered cheapo) but worked plugged staight into the PC, a Belkin powed hub cured the problem. This new one seems to have the same problem, works fine connected to the PC or the Belkin hub but will not work plugged into the hub on my Epson printer.
Hope this helps.
Hope this helps.
Brian.
Brian.
Posted 02/05/2007 - 23:14
I uninstalled it after getting problems,re-booted and re-installed it and it worked a treet Ive just tried it with a usb extension and its messing about taking ages to save an image so its off to ebay for a powerd hub methinks!
Posted 03/05/2007 - 06:53
Maybe you've got a USB 1 extension? The K10D is USB2 and uses a much higher data rate.Ive just tried it with a usb extension
As an aside - we had a Dell LCD with built in hub that worked intermittently. We recently rewired the PC using a new, longer, USB cable and the thing has been fine since. It was the cable all along
Posted 03/05/2007 - 20:51
Hi Mattmatic
As a matter of interest do you know if there is a limit to the length of of USB2 extension cable which may be used when with the REMOTE Assistant Software and a K10D in this set up. ?
Posted 03/05/2007 - 22:07
The USB spec says that 5m of cable should be possible. However, that would depend to a large extent on the quality of the cable.
If I get a mo' I'll try and set it up with a couple of meters (which should normally be more than enough).
Not really any limit on the software...As a matter of interest do you know if there is a limit to the length of of USB2 extension cable which may be used when with the REMOTE Assistant Software and a K10D in this set up. ?
In general the limit should be about 5 meters for USB2 device. Although perhaps 3 meters or so is probably a safer guess at a reliable length.
You can also daisy-chain a limited numbers of hubs to get longer length but that is sort of a pain in the rear.
Any USB 2.0 compliant device should adhere to that.
Ontario,
Canada
One question though, and I apologize if I missed it in the manual... When a picture is saved, it goes to the PC's hard drive (as expected), but is there any way to get it to also go to the SD card? (call me paranoid, but I'd like to have it in both places...)
