Pentax Remote Assistant...
amoringello
Posted 03/05/2007 - 22:11 Link
Argh, I saw you beat me by a few seconds Matt.
Tried to delete my message... but too late again.
I have used a 1 meter extension on the cable that came with the K10D. That is all I have, but at least it makes moving around the laptop a little easier.
boxcam78
Posted 05/05/2007 - 17:16 Link
Thanks guys for the info on the length of USB cables. Are long cables readily available 'of the shelf' as it were or would one have to knock one up for oneself ?
Ammonyte
Posted 09/05/2007 - 15:06 Link
Easy enough to find witha bit of "google magic" http://www.novatech.co.uk/novatech/specpage.html?CAB-USB5MT
Tim the Ammonyte
K10D & sundry toys
Daniel Bridge
Posted 09/05/2007 - 15:41 Link
Is that an extension cable, or a type A to type B cable?
7dayshop do these:
http://www.7dayshop.com/catalog/product_info.php?cPath=777_5&products_id=925...
http://www.7dayshop.com/catalog/product_info.php?products_id=100700
which I think should work. You'd plug the lead from the camera into the adaptor, then the 5m lead from the adaptor to the computer. Should come to £8 including postage.
Dan
Posted 09/05/2007 - 16:04 Link
Various USB extension cables available from Amazon:
HERE
Daniel Bridge
Posted 09/05/2007 - 16:10 Link
Yes, alright, clever-clogs.
Dan
Daniel Bridge
Posted 09/05/2007 - 16:11 Link
Although note that only some of those say USB2. I might be wary of the ones that don't. Still some bargains on there though.
Dan
LiamD
Posted 09/05/2007 - 19:15 Link
if you need a USB lead longer than 5m, then you'll need to use one labelled up "active repeater", due to signal degredation over the length.
Liam
Liam
McBrian
Posted 02/06/2007 - 10:23 Link
Got this from eBay, wasn't much of a loss if it didn't work........
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290113783511
Works a treat, even with a thin 1m extension plus the Pentax 1m cable connected for a total of 7m.
Must say that I was impressed with the seller, had within 2 days and that included a Monday Bank Holiday.
Brian.
Posted 05/06/2007 - 14:15 Link
does remote assistnat work with the ist DS?
Daniel Bridge
Posted 05/06/2007 - 14:23 Link
Unfortunately not, as far as I know. Just the D and K10D.
Dan
Posted 05/06/2007 - 14:50 Link
actually i just downloaded the ist D version and tried it and it seems to work.
not quite sure what use it is though. the screen image is very small, and its not like you can have shutter open continuous viewfinder or anything...
Daniel Bridge
Posted 05/06/2007 - 14:53 Link
Well, no, I did think that when it was mentioned by Don on the other thread. I'm sure it's useful for studio shooting, but it's not something I'd use, at the moment at least.
Dan
Good that it works with the DS though.
Mongoose
Posted 05/06/2007 - 16:32 Link
as far as I can tell it more or less works provided you don't upgrade to the latest firmware. Also probably wise to leave such things as the remote control of custom functions well alone, since the D has different functions.
That is as it appears when used with my DL2 anyway, your millage may vary.
McBrian
Posted 05/06/2007 - 22:23 Link
If you set the Remote Assitant software to Auto Save mode (you don't need a card in the camera with Auto Save mode) and have your editing program open (I use C1 for this) pointing to the path you have set in the Remote Assistant "save to" option you get the picture big and live. Does not seem to take any longer to write to the HD than it does to the memory card (you still get 3+ frames/sec). Couple this with 7m of USB, brilliant for studio work and remote critter shots.
Brian.
