Pentax Q7
Posted 11/06/2013 - 05:39
Just been reading about this on the US forum. Always said the sensor was too small on the original Q and the price was too high.
Of course the original Q has plumtted in price and will plummet even more following the release of a Q7.
What about the Q10? Will this be discontinued?
Posted 11/06/2013 - 06:29
Possibly. Quoting RH.What about the Q10? Will this be discontinued?
"So, what will happen with the original Q lenses then? Well, suppose the image circle is large enough to cover, the 01 "standard prime" lens will become a 35mm standard wide (135 film wise) and the 02 "standard zoom" will become a 21-63mm lens, which I don't think the image circle is large enough for the wide side. Thus, that explains why we saw a new standard zoom patent from Pentax Ricoh before, with a 1/1.7" image circle, details here".
Posted 11/06/2013 - 08:15
As usual time will tell but quote from the other forum:
"apparently all current Q lenses can cover the larger image circle of the Q7"
Carl
Carl
Posted 13/06/2013 - 15:27
If I read this correctly, the Q7 is an MX (same sensor and processor) with interchangeable lenses. Fantastic!
Posted 13/06/2013 - 23:34
All this "new" gear seems a bit marginal to existing users I think. I own a Q and a K30 and my first reaction is what's new? WIth the Q clearly the main feature is the larger sensor. But the picture quality for the sort of thing I would use a Q for is already very good in my opinion. It remains to be seen if there is some really significant improvement anywhere with the Q7 or K90. Good for new users though I think.
Posted 13/06/2013 - 23:52
There can't be too much left out there for manufacturers to improve on in an order of magnitude that would raise eyebrows. How about all prices cut by 50%?
That would at least bring smiles to faces.
Posted 14/06/2013 - 12:47
Should be a cracker, after all the Q is capable of great things, so the Q7 with a bigger sensor and no AA filter should be very good little thing
Posted 14/06/2013 - 14:22
The Q7 (why not Q5?) does look interesting. I think it could do very well. The larger sensor will make a big difference. Pity they didn't put that size sensor in the Q in the first place. I really never saw the point of the Q10 and now it makes even less sense. I'd be a bit hacked off if I had bought one. I can imagine it ending up in cornflake packets now. I could see a reason to still buy a Q because of the different (arguably better) styling and (definitely) better materials quality, but no reason at all to buy a Q10. There must be loads to shift.
Posted 14/06/2013 - 14:41
My wife got a Q10 recently. A larger sensor and better AF are all very worthy upgrades but having tested the Q10 out over the weekend, what it was really crying out for in my opinion was a better LCD screen. Using the LCD to compose shots in bright daylight at unfavourable angles involved a lot of guesswork as to what was in the shot because it was not possible to actually see it properly.
I compared it side by side with the gapless LCD screen on the K-5 II and that was clearly way, way better. This brought me to the conclusion that Pentax really needed to incorporate that technology into the next Q-series camera, after all the LCD screen is the only composition tool available on the Q. Looks like they haven't.
I might consider getting a future Q model for myself, but only if they improve the LCD screen (or add a decent EVF without increasing the size too drastically).
Posted 14/06/2013 - 17:52
There's an identical viewfinder for the GR, so maybe that one will be closer. If not, then a new one for the Q7 could be on the release list soon.
Posted 14/06/2013 - 17:56
GR is 24mm equiv. 01 on the Q7 will be 35mm equiv.
Posted 14/06/2013 - 18:08
Blythman wrote:
Like this from the hands on preview?
"The rear features a 3inch screen, with a new anti-reflective coating"
Doh! haven't read the hands on preview yet... it wasn't mentioned in the blurb I read. Still, I think I would have to try it out 'new anti-reflective coating' doesn't sound like the same technology used in the K-5 II so it may be less (or more) effective.
