Pentax PZ70 - Shutter problems
Lawwolf
Posted 07/05/2007 - 19:23 Link
With a wedding on the way, and a need for a little more than just a little digital camera, i dug out my fathers Pentax PZ70 slr 35mm camera.
Much to my dissapointment i found that the shutter does not work properly, at least not all the time. i found that when i hold the camera upside down it works fine. When i try to use it normally it does not work.
The shutter appears to not complete its cycle.
Does anyone know why this is? or has anyone else had this problem.
Does anyone out there have an idea of how much this could cost to fix?
Many Thanks
Posted 07/05/2007 - 19:55 Link
If it has been out of use for a while you should first check the batteries. New batteries may be all you need.
However, wedding shoots should definitely not be undertaken with any equipment that you are not totally familar with and can operate in your sleep....
Hope that helps!
Lawwolf
Posted 08/05/2007 - 08:30 Link
Hi There,
The batteries were the first thing i changed,
I will also be taking my little digital camera, I just thought since i has this camera i might as well try to use it.
The Pentax website appears to infer that £60 should get it repaired.
I think i'll give it a go.
Many thanks
Mannesty
Posted 08/05/2007 - 12:13 Link
IMHO your £60 would be better spent on ebay. I'm sure there is some sentimental attachment to you dad's camera but that's not necessarily a good reason to start throwing money at it and you could probably replace it with something a lot newer for that kind of money.
Mongoose
Posted 08/05/2007 - 12:20 Link
let's put it this way,
I've just sold a Z-50P on ebay for £23 and was happy to get that much for it.
IMO a Z70 is not worth a £60 repair
Posted 08/05/2007 - 12:21 Link
Even Ffordes.co.uk (which is never that cheap) has several Z70s going for £69 and that will include a warranty
Lawwolf
Posted 08/05/2007 - 20:20 Link
Thanks for all the tips.
I just went onto that website and your right there are some for £69.
I could alway use my old lens.
Thanks Guys.
PS does anyone know if my lens will fit a digital camera.
Posted 08/05/2007 - 20:30 Link
All Pentax lenses will fit the digital SLRs, very early ones with some limitations.
If it is an AF lens there will be no problem.
