pentax optio m60 instructions and a problem
Posted 04/07/2009 - 12:22
Welcome to the forum
Don't have an optio so can't say something about the operation manual but here is the one on their site link
The card problem is strange, it might be that you accidentally have locked the card.
There is a small switch on the side of the card, take a look at that and try if it makes a difference.
Posted 04/07/2009 - 12:51
Hi there, welcome to the forum
As Stefan say maybe the card has been accidentally locked or perhaps there is a memory card fault.
Do you have another memory card you could try?
You can download the full manual as a pdf here http://media.pentax.co.uk/downloads/photo/en/17394/optio%20m60.pdf
Posted 04/07/2009 - 13:21
Is the small slider switch on the card in the "lock" position?
Posted 05/07/2009 - 09:03 - Helpful Comment
Hi,Thank you for all your replies as you helped me to solve the problem it was as some suggested the little slide on the memory card,i would never have found the "fault" without all your help .
Thanks also for the site to download the manual .Dutchyjohn
Posted 06/07/2009 - 19:05
Hi and welcome.
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
K-1ii,K-3iii's.
