Pentax MZ-S - Flash Issue
Posted 17/03/2025 - 16:19
Does it work on hotshoe?
Posted 18/03/2025 - 10:59
Not sure, I assume so but haven't checked since it still has the protective cover, but don't really want a flashgun as I quite like the relatively small size and weight of the camera as it is.
Posted 18/03/2025 - 13:56 - Helpful Comment
I presume you have confirmed lack of operation by putting fresh batteries in the camera? Always find that when a flash hasn't been used for a while it throws a tantrum (not just limited to Pentax) and takes a while for the innards to get up to speed.
Failing that, consider a compact Pentax (or compatible) flashgun, more power but not as bulky as the AF500FTZ (which is also prone to tantrums),
Z-1p, K-1, P50
Posted 18/03/2025 - 15:24
Thanks, yes even with fresh batteries it doesn't want to play - in fact it gives the low battery symbol but when you switch on and off that clears up and camera seems fine . .. just old electronics I guess!
