Pentax MX focusing tips
Posted 04/05/2009 - 09:58
I find the microprism collar is more useful than the split prism itself.
Posted 04/05/2009 - 10:15
I get on better with the split prism so it really is a case of each to their own...
If I'm taking a picture and there is no good vertical line I simply move the camera into portrait mode, use a horizontal line, then flip the camera back down again.
Joining the Q
Posted 04/05/2009 - 11:48
The viewfinder optics result in the focusing screen being effectively about 1 metre away from your eye. If you need glasses for reading or for your computer screen, try using these when looking through the viewfinder and you may find that suddenly it becomes very easy to focus.
There are eyepiece adjustment lenses available as well.
As regards focusing I usually just turn the focusing ring until the image looks sharpest in the viewfinder. The central focusing aids are the split image and the microprism collar.
The split image - just find a sharp line and focus until the line becomes one and is not displaced.
The microrism collar will shimmer until focus is achieved. When the shimmering stops you are in focus.
The difficulty arises when all three methods give you different focus points, but you won't be far out.
Posted 04/05/2009 - 12:05
That what I have been finding that if I focus until I think it is in focus is not always the same as when the split image is correct.
K30 & 18-55mm WR.
Posted 04/05/2009 - 12:28
The split image might be more accurate, but only if your eye is centred.
I would just use one method though, whichever you find most comfortable.
Posted 04/05/2009 - 12:49
I tend to use the centre split image as John suggests, this is usually better at wider apertures.
For f8.0 on it's just a case of hoping for the best.
Cheers, HG
PPG entries.
PPG entries.
Berkshire,
England
I know this is probably something that takes a little time to learn but has anyone got any tips I can use on focusing the MX ?
Jason
