Pentax MG questions
Posted 24/08/2009 - 19:07
How old is the lens? it could be fungus,
Posted 24/08/2009 - 19:39
no idea how old it is, anything i can do to it?? or any explanation to why it only some times happens??
Posted 24/08/2009 - 20:22
This happening where the dark outlines are against a bright sky, causing colour fringing. It's a lens defect and it won't appear on general front lit subjects. It will be particularly noticeable with branches against bright sky.
What lens is that?
What lens is that?
Posted 24/08/2009 - 20:36
I had a lens like that it was a 30 year old Pentax manual 28mm, at f2.8 it was fuzzy at the edges, at under f8 it was fine, turned out to be fungus which starts from the edges of the lens, I stripped it and cleaned it and it's been fine since. Try taking a photo under f8 and see if it has the same fault.
Jack,
Jack,
Posted 24/08/2009 - 20:40
the lens was Pentax-M 1:2 50mm f/2, I suppose there isn't anything i can do about it then?
I didnt think that it was just branches on bright sky, kinda new to these things.
Posted 24/08/2009 - 21:14
What's written on the front of the lens. It's possible that the lens is only designed for digital cameras.
Posted 24/08/2009 - 21:16
Yes you can if that is what the problem is, and it still could be what John said,
have a look at my thread,
Jack.
https://www.pentaxuser.com/forum/topic/pentax-m28mm-2-8-with-fungus-12949/p-0#comm_127182
Jack.
Posted 25/08/2009 - 13:03
thanks jackitec. how do i check if it is moldy? Because johnriley said it could be that colour fringing problem so I'm not sure what it could be.
I had a look and i can see some dust on the inside lens but i doubt its fungus.
greynolds: The lens is the original one that was made with the camera in 1980 something BC so its definatley for tis camera
Posted 25/08/2009 - 14:14
Hi Danny, the fungus look likes tiny white worms not like mold, have a read at this http://www.mypentax.com/Fungus.html and checkout the photo
other to what John said I can't think of anything else sorry,
Jack.
Edit, this is a very severe case.
Jack.
Posted 25/08/2009 - 18:57
Its not a fungal infection then, must be the color fringing, but thanks for bringing to my attention, now i know what to look for in the future.
and my other question was about mounts, will the mg fitting lenses fit on the K-m (k2000) fit??
Posted 25/08/2009 - 21:49
In short yes, every Pentax lens ever made will work on any Pentax digital, although you would need a converter if you use screw fit. Anything which fits the MG will fit the K-m/K2000.
link pictures without blurred corners
Another question. Can i still use the lenses that fit the MG onto the KM?
i heard that they both use the same K mount so i assume that they will work.
