Pentax litium battery not working properly.
AuraTodd
Posted 19/11/2013 - 17:07 Link
Can someone help me please? I have a battery which came with my pentax K30 camera since last Christmas and it came with charger and pentax battery.
When ever I charge it, a green light comes on which then turns off after a few seconds which is a pain in the back side. The battery was almost empty, so I know it wouldn't be ready yet. I usually put the battery into the charger with a soft click.
I told a friend of mine and he said it was because I hadn't been letting the battery run down and probably that the battery could be weakening, but I went into the camera shop and they said this wasn't likely.
Can you tell me if this could be my chrager, or a bettry problem? One bloke said there could be something wrong with my camera, which I don't think so, or it wouldn't work.
Posted 19/11/2013 - 17:47 Link
Batteries do need proper care and charging routines, but it isn't necessary to let Lithium cells run down completely.
Maybe there's a charger fault, it does happen, but maybe the battery has reached the end of its life. I understand 1000 charging cycles might be expected. Towards the end of that efficiency will tail off gradually.
How to find out is perhaps to buy a new battery or try charging your own battery in another copy of the charger unit. Maybe the shop would let you use a charger? Or send it to someone to charge for you? Anyone near Salisbury who would give AuraTodd's battery a charge to check it out?
AuraTodd
Posted 19/11/2013 - 19:40 Link
Already? Only had it since last Christmas, will get a spare one, but will take it to shop and see if they could test the battery.
Can you recommend a realisble spare lithium battery please?
JAK
Posted 19/11/2013 - 19:45 Link
If its less than a year old, get back to the shop with it ASAP and get them to sort it out under its warranty.
AuraTodd
Posted 19/11/2013 - 19:53 Link
WEll I got it from SRS Microsystems which is in London, do I ring them up? I don't know to contact them.
bforbes
Posted 19/11/2013 - 19:56 Link
I would give them a telephone call link
jeallen01
Posted 19/11/2013 - 22:09 Link
If necessary I could lend another battery and genuine Pentax charger as I have spares after getting the k-30.
Would have be by post as I live in W.London though!
John
Gamka
Posted 20/11/2013 - 01:36 Link
John
Don't even think about posting a battery without fully checking the Royal Mail Ts&Cs about packaging.
They are getting to be a real pain. A friend sent an empty lighter case back for repair - RM destroyed it even though when accepted by the Post Office they knew what was it in and completed the form.
Pentaxophile
Posted 20/11/2013 - 06:15 Link
Aura, you can get unbranded spare batteries from eBay and 7dayshop. Very cheap and work acceptably well as a spare (I've never had any problems) and at least you could check to confirm whether it really is your battery at fault, or something else.
AuraTodd
Posted 20/11/2013 - 09:44 Link
It worked after I pushed it in a couple of times, but I will ring them up and see what they say. Thanks jeallen01 that's very kind of you, but I think Royal mail woud probably dispose of it.
They destroyed a heart monitor once my friend so vitally needed, before the hospital sent her one in person.
JAK
Posted 20/11/2013 - 10:42 Link
Make sure the battery contacts on the battery and in the camera are clean. A normal pencil rubber is pretty useful for cleaning the battery contacts, especially those that are made to look like a pencil.
