Pentax K5
Posted 06/01/2014 - 10:45
Looks like you might have inadvertently set the camera for 'remote release' Press the timer button (top of the 4 on the 4-way controller) and see which option has been selected. The camera will still take pictures normally in this mode using the shutter release button; however I think that the SR function might be disabled
Hope that helps!
Hope that helps!
Andy
Posted 06/01/2014 - 17:58
Thanks for that - I had been experimenting with a remote!!
Posted 06/01/2014 - 19:36
russellcowe wrote:
.... The main display info panel also flickers in unison...
Well that bit is not normal, I don't think so? I'm not aware of the LCD display flickering in any mode, certainly not in unison with the remote indicator. I'm a K7 user, but the K5 is identical is these respects AFAIK.
Posted 06/01/2014 - 20:22
The numbers could flash ... though not in unison with the remote indicator.
Posted 07/01/2014 - 10:20
Theoretically it's possible that they 'flash' in sync.
When LED is on, there is less power available for the LCD and it will be a little less bright. And when the LED is off, there is more power available and the LCD will be a bit brighter.
You can compare it to a car with a faulty ground / earth; switch the indicator on and another light starts flashing / dimming in the rhytm of the indicator.
One possible cause for the above can be a battery that is reaching end of life. And another one a bad ground (as described).
Please note that this is a / my theory.
Can't find this in the manual, does anyone know what it means? How to switch off?
Camera is functioning correctly.
