Pentax K3ii and Metz Mecablitz 50 AF-1
Posted 26/01/2021 - 17:49
More info if it helps, can get an exposure at 1/180th anything faster is just a dark screen. it is as though the flash is too fast for the camera or vice versa. firmware up to date. works fine with !st DL so a K3ii problem with it by the look of it.
Posted 26/01/2021 - 18:57
Would suggest you need to go for after market triggers, I've gone for cactus which work very well but I understand have now stopped production so godex may be your only current option.
Chris
Posted 27/01/2021 - 19:31
Is it because the *istDL is TTL compatible but not P-TTL ?
Posted 28/01/2021 - 12:52
Pleased you got it sorted
Chris
Posted 28/01/2021 - 13:56
redbusa99 wrote:
HOORAY!!! downloaded and installed firmware even though latest version was shown as being on it , a last ditch attempt at trying anything and it worked now doing exactly what it should
Just to satisfy my curiosity...was this the firmware on the camera, or the flash unit ?
Posted 28/01/2021 - 19:28
Thanks. I've got a K3/Metz, so that could save me some head scratching should I encounter anything similar
stroud,glos
