Pentax K3 ii and back Button Focusing
Posted 28/02/2021 - 22:46
Are you using the camera shake reduction or the lens image stabilisation?
Best to use one or the other. If you use both they start to fight each other!
All the best, bob.
All the best, bob.
Bob
Posted 28/02/2021 - 22:53
All the best, bob.
Hi Bob, I've tried both but not at same time, if back button is used the lens shake reduction doesnt work anyway because it needs the shutter half press to trigger it. I've been shooting at 1/1250 second so altough shake reduction may help I dont think it would be critical. The Sigma lens can be set to pan mode but it doenst seem to help either.
All the best, bob.
Posted 28/02/2021 - 23:06 - Helpful Comment
How is the focus on static things? You may need to do some focus adjustment. Won't help with tracking, but might improve the results when it does.
Posted 01/03/2021 - 09:44
Static focusing is pretty good provided I use the half press shutter method. Probably no sharper than the K5 ii but as the detail from the sensor is better it probably makes the final image better. I'm pretty sure the focusing of the lens is pretty well spot on, if I let the camera auto focus on a subject I cant improve it by tweaking the focus ring. How is the focus on static things? You may need to do some focus adjustment. Won't help with tracking, but might improve the results when it does.
My real gripe is a cant get the back button to work as I think it should with birds in flight.
Posted 01/03/2021 - 10:13 - Helpful Comment
Mike might be able to help. I rarely photograph things that have moved in the last century or so...
Posted 01/03/2021 - 10:15
Hand held Sigma 150-500 at 500mm, 1/500 sec, ISO 100, spot focus.
These are images of Little Egret, before and after cropping. I dont think there is much wrong with the focusing although I did use some sharpening in RAW edit and I applied PSE editor's shake reduction to tweak it a little more, it wasnt bad before.
Posted 01/03/2021 - 10:23 - Helpful Comment
The sample images look pretty good to me even as small as they are. When I use BBF, and its generally on larger metal birds in flight than the feathered variety, I have spot focusing enabled.
Chris
Posted 01/03/2021 - 10:29
Dont think I've tried spot focusing with BBF because I struggle to keep birds in the centre. When you use BBF and spot focus do you have to keep the plane in the centre of frame for BBF to stay locked on it?
Posted 01/03/2021 - 10:48 - Helpful Comment
[/quote]Dont think I've tried spot focusing with BBF because I struggle to keep birds in the centre. When you use BBF and spot focus do you have to keep the plane in the centre of frame for BBF to stay locked on it?[/quote]Not generally, but it helps to keep the largest part within the spot focusing area. BIF images with pentax is more difficult imho than perhaps other manufacturers, its a skill that takes honing and the success rate perhaps isn't as many as canikon, but when you do get it right, its worth it !!
The Hawk is a tad noise, shot at 1600 ISO ( K3ii )
Chris
Posted 01/03/2021 - 10:54
[/quote]Right I'm going to persist with it, we get plenty of aircraft here so will try them first, they are more predicatble. What do you use, "select spot" or "spot"
Posted 01/03/2021 - 11:46 - Helpful Comment
Go just for " Spot " David
Chris
Posted 01/03/2021 - 12:40
Thanks Chris,
