Pentax K20D & Metz 45 CL 4
geedee
Posted 28/05/2009 - 08:22 Link
Newby Question
Can I use a Metz 45 CL 4 Flash on my Pentax K20D safely with out damage to the camera.
I have a S300A Lead and a single pin Hot Shoe Adaptor ( which I think you refer to as a dumb adaptor)
From reading various sites my understanding is that i can use the flash in Manual / Auto Mode by selecting the appropriate apeture
I also have a S3702 adaptor but not sure what lead i should have to match this adaptor.
GeeDee
Posted 28/05/2009 - 10:04 Link
I'm pretty certain the trigger voltage of the 45CL series will be just fine. When using the "dumb" adapter you should set the camera to manual, or Av mode - set the aperture and ISO on both camera and flash and use a shutter speed slower than 1/180s.
NOTE: If you use Av mode, make sure the camera is in fixed ISO mode, not automatic!!
The SCA3702 may fit onto your SCA controller for the 45CL-4 (I'm not sure). I use the SCA3702 on the Metz 50MZ5 gun and it provides the correct tethering of ISO and Aperture - so Av mode on the camera is a breeze. Check out the Metz website for manuals and compatibility lists.
I also have an "e-book" PDF that you can purchase which gives some extra hints for setting up the K20D etc and using flash
geedee
Posted 28/05/2009 - 11:45 Link
Thankyou for your response Matt
Hopefully you are correct.
This Flash unit has been used on a ist DL with no problems.
Can only assume that the K20D is constructed with the same parameters.
GeeDee
