Pentax K10D and Flash Triggers
Maplins:
2.5mm jack (JK00A) 99 pence
small toggle switch, mom on-off-perm on (FH02C) 2.29
Thanks for replying. What is the jack for?
Paul.
I think K10D is momentarily confusing this with a remote release.
Time to plug in the common sense cable me thinks....
If a Nikon or Canon transmitter was plugged into the Pentax hot shoe wouldn't the extra dedicated pins connect wrongly to the camera and cause problems?
Cheers,
Paul
Hello,
Cheers,
Paul
The radio triggers I'm looking at are the RF-602. They are reviewed here:
http://scubajunkie-mymind.blogspot.com/2009/09/yongnuo-rf-602-review-couple-of-y...
From the photo there are dedicated pins on the receiver for either Nikon or Canon flashguns. I assume the same is for the transmitter. Apparantly these connections provide high speed sync and wake up functions for the flash.
I'm concerned about these connections mating with the camera connections which may serve different functions for a Pentax camera.
Regards,
Paul.
I've just bought Twinlink T2D and the build quality is good a bit expensive but i think they are worth it and the range is 600m i think and can be fired with out being in direct sight
James
These are the ones I use with studio flashes: link
They've been working well for about three years.
I've just fired a strobe through two closed doors at 100ft
James
range in doors 150ft out doors 600ft out doors 2.4 GHz RF & IR 16 Channel LCD display with back light strobe and flash
Hello,
Cheers,
Paul
For simple remote flash triggering the PT-04's work well for me.
RF 602 triggers are indeed dedicated but they still will work with Pentax. The dedication allows them to wake up flash at half press of a shutter. If you re using them with old flashes or ones that don't go to sleep after few minutes, they will be fine with any camera.
In fact i just ordered this exact triggerss from dealextreme.com. Good price but slooow shipping.
Marcin
The RF-602 remote flash triggers on ebay are advertised as compatible with Canon or Nikon cameras. I've heard that these can also be used with Pentax. Can anyone tell me which type (Nikon or Canon) would work with my K10D?
Thanks,
Paul.
