Pentax K-X Query re Viewfinder
Posted 21/10/2009 - 12:06
I almost always use centre focus point anyway. That way I know where the camera is going to focus and can help it along in low-light situations (by pointing the centre at something with decent contrast)
Posted 21/10/2009 - 12:09
With the other Pentax cameras except the K-M you see a red square on the point it focus on so you know on what area the focus is.
If a lot of objects are close to the plane of focus I can see that you might have trouble spotting on which the camera is focusing on.
Most of the time though that isn't the case and it is quite clear of the object is in focus or not.
Posted 21/10/2009 - 12:12
Overlaid AF points will highlight which focus point has locked focus.
eg: Say your main subject is near to you on the right hand side of your frame & you wish for that to be in focus whilst the rest of frame is out of focus, then you'd want a focus point on the right hand side to be used, but without overlaid info, the points on the left may have been used which ultimately would mean your subject is out of focus.
I turn off the multiple points & use the centre focus point only to focus on my subject & then re-compose my frame as I want so it would be no great loss to me really.
Posted 23/10/2009 - 19:40
Thanks Matt, Stefan and Bob for your comments on my question. I've tried my k20 and turned off the Red Focus Overlay and see that the focus is confirmed by the audible Bip, so maybe a K-M user might confirm if the focus is confirmed by the audible Bip ( as that would probably apply on the K-X).
Many Thanks
EddieD
Many Thanks
EddieD
EddieD
K5
Tamron Di11 SP AF 17-50mm F/2.8 XR
Sigma 50-200mm F4-5.6 DC OS HSM
K5
Posted 23/10/2009 - 19:50
.... and the green hexagon at the bottom of the viewfinder.Thanks Matt, Stefan and Bob for your comments on my question. I've tried my k20 and turned off the Red Focus Overlay and see that the focus is confirmed by the audible Bip
Screen shot of the KM viewfinder, you don't see the red squares though.
Posted 23/10/2009 - 20:38 - Helpful Comment
Unfortunately, the K-M I used would sometimes focus on an object that that appears (in the photo) immediately next to my desired subject although that object is some considerable distance in front of or behind my subject.
An example is a person seated at a table across from me with a wine bottle just to one side between us. It's a great photo with shallow DOF - but only if the person is properly focused and the bottle is not. It may be carelessness on my part. I prefer the K7/K10 arrangement as I, at least, can be more confident of the focused-upon object.
Posted 23/10/2009 - 21:30
Thanks again Stefan for taking time to reply. Thanks also Geoffrey, your views and experience are very interesting and helpful.
EddieD
K5
K5
Dublin,
Ireland
"Though the camera includes Pentax's 11-point SAFOX VIII AF system, it is hampered inexplicably by the lack of an AF-point overlay in the optical viewfinder, which means there's no visual confirmation of which points are in focus."
As a relative newbie, I'm not sure how this would effect one's ability to ensure the camera had focussed correctly. Any views or thoughts would be welcome
EddieD
K5
