Pentax K-X and continous shoot in sports mode...
Posted 20/05/2010 - 07:44
Are you shooting in RAW or JPEG?
Posted 20/05/2010 - 08:00
JPEG. I figure that is the best choice?
Posted 20/05/2010 - 08:14
Definitely need to shoot in jpeg, and try using a class 10 card.
Posted 20/05/2010 - 08:31
Hmmm... That is something that crossed my mind but figured class 6 was sufficient. Is it noticably diffrent?
Posted 20/05/2010 - 11:40
It all depends - the class ratings are based on a synthetic benchmark averaging read and write performance using (IIRC 64k blocks) - this is not the only way you can drive an SD card. This means that my Panasonic class 10 card is poorer in performance than a Sandisk Extreme III class 6 and is useless for recording video on a GF-1 or K7 as it uses the incremental write profile rather than block writes.Hmmm... That is something that crossed my mind but figured class 6 was sufficient. Is it noticably diffrent?
I think it is best described that not all class 6 are created equal.
Chris
edit: On my K20D and with a class 6 Sandisk Extreme III I can do bursts of 30ish JPGS before lockup - you should get at least 15 with a K-x
Posted 20/05/2010 - 11:41
"Definitely need to shoot in jpeg, and try using a class 10 card. "
A class 6 card should be good enough & I'm doubtful whether class 10 would make any difference whatsoever. My K-7 only requires class 6.
Pentax specs "Multi-Exposure Continuous FPS: Approx 4.7 FPS (Continuous Hi: 17 JPG, 5 RAW), 2 FPS (Continuous Lo: unlimited JPG, 11 RAW)"
I wonder about your card, perhaps you should try another one. Then if the card is OK I would wonder about the camera. You could try re setting the camera to factory defaults - you never know but that might help.
Regards, Ian.
Regards, Ian.
Posted 20/05/2010 - 12:53
I'm using a Sandisk class 6 and clearly for consecutive shooting after 3 shots the buffer is loaded so not benefitting the advertised 4.7fps 17 shoot sequence I would like with this memory card. If it isn't the card what is it??? Has anybody used a class 10 with a K-X with sucess and achieved this frame rate and burst?
Posted 20/05/2010 - 12:55
I think I'll have a good look at all the settings. :-/
Posted 20/05/2010 - 14:33
Wild speculation:I think I'll have a good look at all the settings. :-/
I wonder if formatting the card will have an effect - if the file-system on it is fragmented it could slow down rates. Try a deep format when the card is plugged into the PC. I had a Ricoh that wouldn't do bursts unless I had formatted the card beforehand.
C
Posted 20/05/2010 - 14:53
Setting are correct. Set for JPEG. 12mp. Tried again... First 3 are taken fast then about a second lag before shoot 4 is taken and likewise for the 5th etc...
I formatted the card via camera. Same result. I did a full format on PC. Same result. I'm awaiting delivery of another memory card (same spec/type but 8gb instead of the existing 4gb) and will try this out. It could be the card is simply ok for normal camera use but too slow (despite being class 6) for continuous drive. Will report back.
Would be great to know if there are any K-X owners out there with this problem.
Thanks again...
Thanks again...
Posted 20/05/2010 - 15:06
Cards should be formatted in the camera they are to be used in.
Posted 20/05/2010 - 17:01
Tried card formatted both ways. Both giving same result. Will try lens correction!
Will report back. Thanks for all your suggestions so far.
Posted 20/05/2010 - 17:09
The K-X has a buffer that can hold 5 RAW photos or 16 jpg's therefore the performance of the first 3 photos can not be influenced by the speed of the SD card.
Also the fastest official SD class is 6, Class 10 isn't official so far as I know.
Also the Sandisk extreme III are very fast cards, 20mb/s or 30mb/s if you have the new ones so speed can surely not be an issue here.
I'm new to DSLR and was attracted to this. It is, so far, a great piece of kit.
I am using Sandisk Extreme III (Class 6) memory cards. On the whole I find them good. I've tried the camera yesterday taking action shots of my dog but found in sports mode and continuous shooting that I am able to take only 3 shots before it pauses. I believe the camera is able to shoot at 4.7fps and up to 17 shot sequence. This is obviously not happening.
Any tips or help welcome. Was wondering if my memory card wasn't quick enough. Any recommendations?
Jaq
