Pentax K mount lense
Posted 21/10/2007 - 10:34
If it were a K fit lens it would fit, and although some independent lenses don't fit as slickly as a Pentax one will, the Vivitars are not bad.
So are you sure it is a Pentax K-fitting lens? If it's a screw fitting lens you will need the Pentax Adapter K, but if it's some other bayonet fit then there is nothing that can be done.
Posted 21/10/2007 - 12:22
Thanks - It looks like a K fit and says P/K on the side so appears to be....
Just won't sit far enough down to turn....
Strange...
Strange...
Posted 21/10/2007 - 12:28
Whatevere you do, don't try to force it. If you compare it with a Pentax K fit lens is there anything obviously bent or damaged on the back of your Vivitar lens?
Posted 22/10/2007 - 07:46
Does the lens say something like Pk-R??
If this is the case - it wont fit unless you do some work on it.....
I had a vivitar lens I had to refit to the K-bayonet.
It now works extremely good.
Take a picture of the bayonet and post it....
Posted 22/10/2007 - 07:56
Just fund my last post about it.....Not sure this will help you but take a look.
I can take a picture of the rezised flange - if this is the case...let me know.
https://www.pentaxuser.com/forum/viewtopic.php?t=5468&highlight=vivitar
Any ideas.... ?
