Pentax K 5 II noise
Posted 13/02/2015 - 04:03 - Helpful Comment
Are you shooting raw or jpeg?
Can you post a resized example with EXIF intact?
Posted 13/02/2015 - 09:09
Posted 13/02/2015 - 09:13 - Helpful Comment
That's iso3200 which is not relatively low. It is a dark scene which is more prone to noise, if you lift the shadows then you will intoduce more. I suspect what you are seeing is completely normal.
Posted 13/02/2015 - 09:16
Posted 13/02/2015 - 09:32 - Helpful Comment
Same comment applies.
Posted 13/02/2015 - 09:47
any solution?
Posted 13/02/2015 - 10:22 - Helpful Comment
Take such photos at 1/30th of a second, or lower if you have a steady hand. problem solved.
Posted 13/02/2015 - 10:24 - Helpful Comment
The K-5 has remarkably little noise, and I happily use it up to ISO 1600 without any trouble, albeit it usually in good light levels.
In low light levels, the answer is a truly low ISO (say up to ISO 200) and a long exposure with the camera firmly on a tripod. If you shoot JPEG the camera will sort out noise reduction, and you can adjust the parameters for this in the menus.
If you are shooting RAW then there may well be noise reduction in the RAW converter, or you might use stand alone software.
Hope that helps.
Hope that helps.
Posted 13/02/2015 - 10:48 - Helpful Comment
With a focal length of 700mm or more (in the sample photos), you must have an extremely steady hand.Take such photos at 1/30th of a second, or lower if you have a steady hand. problem solved.
I wonder what is going on with that :
Posted 13/02/2015 - 10:57 - Helpful Comment
Sorry, I hadn't seen the extremely long focal length used. I'd say 1/100th is challenging and presumably the aperture the widest available.
Posted 13/02/2015 - 11:00 - Helpful Comment
Somehow I don't think it is really a 700mm f4.
11 years
any suggestions?
Thank you
