Pentax DSLR EXIF Data in Different Programmes
Posted 25/02/2015 - 01:41
PDCU is created by Silkypix ppl as far as I know. Unfortunately, SilkyPix (as supplied with the K-0, the Q, the MX-1 and K-50) shows only a limited EXIF. So it's next to useless to show all the EXIF tags.
PIE shows them all.
However, EXIFtool will extract the meta data verbatim from the image file and save it to a .txt file
DOWNLOAD link for txt file:
► https://www.dropbox.com/s/t1cak3z0ftgf3b8/my-k-50-and-some-lenses-_1424762782.tx...
EXIFtool ► http://www.sno.phy.queensu.ca/~phil/exiftool/
PIE shows them all.
Posted 25/02/2015 - 01:49
This issue of 'Silkypix' being provided instead of Pentax Digital Camera Utility crops up sometimes .... was it also issued with the K30 I remember?? It seems bizarre to me that the same PDCU is not used and updated to cover all the Pentax cameras. Based on my testing so far I would not expect a standard version of Silkypix to offer much intelligible information, no more than Photoshop seems to anyway!
Now the metadata extracted from the file is not much use unless it is translated and presented in a way that matches (maps to) to exact camera set parameters .... this is what PDCU seems to achieve with its wealth of helpful data. I'd assume that in order for any third party software to offer this ability that it would need to be updated regularly with Pentax - specific coding ...??
Posted 25/02/2015 - 02:14
EXIFtool is extracting exactly what's embedded, not it's own interpretation. And is platform independent, no interference from Windows.
EXIF is a standard and tags that can't be understood by various softwares are ignored and then stripped when saving out the edited JPG.
But I'm over this discussion already.. You might be trying to convince me that anything but PDCU is wrong, but I don't buy it. But you are allowed an opinion too
Posted 25/02/2015 - 02:24
Look, its not about right or wrong ... no doubt the tools you mention do extract the base data ... I saw loads of information in the Photoshop file info dialogue (things like 'Saturation 25') etc .... loads of information that did not directly present the same values as the actual camera settings.
Its about the usefulness of the information ... thats what I'm questioning. If someone is going to be advised to, for example, reduce the contrast setting they use, then (for example) if they had started off with a setting of '+3', then you'd want to see that in the metadata .... then you advise say 'try +1' ..... its not much help to see something like 'Hard' .... you can't advise to try 'less hard', or 'soft' .... they don't exist on the camera! The only thing that makes any practical sense is the exact actual numerical value as set on the camera.
So far, from what we're seeing here, the only software that correctly and fully provides all of this helpful data is PDCU. What actual use is any of the other data shown in some of the alternative tools that have been mentioned ... is there anything useful?
Amongst the mass of data I saw in Photoshop, the only really useful fields were generic things like focal length, camera name, copywrite holder, flash on / off .... in most cases the PDCU values were exactly as we choose on the camera .... in photoshop they were something different, something that felt like an unreliable translation.
Posted 25/02/2015 - 02:25
See technical point #2:
link
The standard defines a MakerNote tag, which allows camera manufacturers to place any custom format metadata in the file. This is used increasingly by camera manufacturers to store camera settings not listed in the Exif standard, such as shooting modes, post-processing settings, serial number, focusing modes, etc. As the tag contents are proprietary and manufacturer-specific, it can be difficult to retrieve this information from an image or to properly preserve it when rewriting an image. Manufacturers can encrypt portions of the information; for example, some Nikon cameras encrypts the detailed lens data in the MakerNote data.
link
Posted 25/02/2015 - 02:36
So could it be the case then that Pentax are not updating or providing their camera - specific data into this MakerNote format? But then again, do users of other camera brands get all their custom image settings correctly spelt out in third party exif readers or even industry-standard software? Surely it can't just be Pentax where that is not happening .....
My concern here is that there may have been an assumption amongst Pentax users that they had a reliable data record within their files, easily viewable and understandable .... and that this is not in fact the case ... that we actually need to use PDCU to view accurate and full camera setting information.
Posted 25/02/2015 - 02:50
Seriously haven't paid much attention to this conversation, but it's potentially the other way around. It looks like there is a section allowed for, for the company to do with as they please. Other software may not make use of it at all, or if Pentax have changed their format in this section it then wouldn't make much sense to any other software that was originally using it. The onus would be on software manufacturers to stay in touch with however Pentax and other brands were using this ungoverned field over time.So could it be the case then that Pentax are not updating or providing their camera - specific data into this MakerNote format?
Personally I don't really care if I'm honest. I don't go near this info at all, and focus on the final image. I can see how others might use it though, despite it not being part of my personal workflow.
Posted 25/02/2015 - 02:57
I would say its use is more for image analysis after the taking ... such as looking at where things have gone wrong (which is the scenario that this all arose from) and where certain settings might have an impact.
Apart from just the JPEG custom settings there is a range of other very useful information that is displayed in PDCU .... eg the metering modes, AF mode, AF point selection, the exact WB fine tuning setting (eg 'amber +5), flash compensation ... a whole lot of good stuff if you're looking into how you've set up the shot and the impact these things might have.
What I find amazing is that this information is only available in PDCU, and yet it appears there has been this assumption that it is all there laid out in other software, 'extracted' ready to be seen and understood .... but I am just not seeing evidence of this at all .....
Posted 25/02/2015 - 03:02
Did you look at the EXIF tool output (link in my post) and compare it with what you see in your version of PDCU?
Posted 25/02/2015 - 03:05
I tried, but I'm on a work network at present, I can't access any sites that are classed as 'storage' or 'file sharing' .... sorry . But I'll try on my phone .... stand by!
Posted 25/02/2015 - 03:13
I'll post here if the character limit doesn't truncate...
---- ExifTool ----
ExifTool Version Number : 9.75
---- File ----
File Name : my-k-50-and-some-lenses-_1424762782.jpg
Directory : .
File Size : 362 kB
File Modification Date/Time : 2015:02:24 19:29:30+10:00
File Access Date/Time : 2015:02:24 19:29:30+10:00
File Creation Date/Time : 2015:02:24 19:29:30+10:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Big-endian (Motorola, MM)
Image Width : 1000
Image Height : 664
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
---- JFIF ----
JFIF Version : 1.01
Resolution Unit : inches
X Resolution : 300
Y Resolution : 300
---- EXIF ----
Make : RICOH IMAGING COMPANY, LTD.
Camera Model Name : PENTAX K-3
Orientation : Horizontal (normal)
Y Resolution : 300
Software : PENTAX K-3 Ver. 1.11
Modify Date : 2015:02:22 22:08:54
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/50
F Number : 4.0
Exposure Program : Program AE
ISO : 1600
Sensitivity Type : Standard Output Sensitivity
Standard Output Sensitivity : 1600
Exif Version : 0230
Date/Time Original : 2015:02:22 22:08:54
Create Date : 2015:02:22 22:08:54
Components Configuration : Y, Cb, Cr, -
Exposure Compensation : 0
Metering Mode : Multi-segment
Flash : Off, Did not fire
Focal Length : 26.0 mm
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 6016
Exif Image Height : 4000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Auto
White Balance : Auto
Focal Length In 35mm Format : 39 mm
Scene Capture Type : Standard
Contrast : High
Saturation : Normal
Sharpness : Hard
Subject Distance Range : Close
Offset Schema : -414
GPS Version ID : 2.3.0.0
Compression : JPEG (old-style)
X Resolution : 300
Y Resolution : 300
Thumbnail Offset : 32014
Thumbnail Length : 4329
---- MakerNotes ----
Pentax Version : 11.0.0.0
Pentax Model Type : 0
Pentax Model ID : K-3
Date : 2015:02:22
Time : 22:08:54
Quality : Best
Flash Mode : Off, Did not fire; Internal
Focus Mode : AF-A (Focus-priority)
AF Point Selected : Auto; Single Point
AF Points In Focus : Upper-middle
F Number : 4.0
ISO : 2500
Auto Bracketing : 0 EV, No Extended Bracket
Saturation : Normal
Contrast : Med High
Sharpness : Med Hard
DSP Firmware Version : 1.11.28.18
Effective LV : 5.3
Image Editing : None
Picture Mode : Unknown (3 22); 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Color Space : sRGB
Data Scaling : 8192
Lens Type : Sigma 18-250mm F3.5-6.3 DC Macro HSM
Sensitivity Adjust : 0
Image Edit Count : 0
Camera Temperature : 19 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0; 0
Image Tone : Bright
Shake Reduction : On (AA simulation type 1)
Shutter Count : 1927
Faces Detected : 0
Face Position : 0 0
Raw Development Process : 13 (K-3)
Hue : Normal
White Balance Auto Adjustment : Off
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : Off; Auto; 0; 0
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : Berlin
Destination City : Berlin
High/Low Key Adj : 0
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Auto; Active (Weak)
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : On (5 faces max); 0 faces detected
Face Detect Frame Size : 0 0
Shadow Correction : Auto
ISO Auto Parameters : Standard
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : Off
Vignetting Correction : Off
Bleach Bypass Toning : Off
Aspect Ratio : 3:2
HDR : Off; Auto-align Off; n/a; 0
Black Point : 1 0 2 0
White Point : 14272 8192 8192 17792
AE Exposure Time : 1/51
AE Aperture : 4.0
AE ISO : 2263
AE Max Aperture : 4.0
AE Max Aperture 2 : 4.0
AE Min Aperture : 23
AE Min Exposure Time : 1/7723
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Focal Length : 26.3 mm
Nominal Max Aperture : 4.0
Nominal Min Aperture : 23
Max Aperture : 3.9
AE Metering Segments : 10.3 10.4 10.3 10.3 10.1 10.0 9.8 9.8 9.8 10.1 10.5 10.6 10.6 10.8 10.6 10.4 10.0 9.4 8.3 7.3 6.5 6.8 7.1 7.9 8.1 7.8 7.3 7.0 7.3 7.4 7.6 8.0 8.4 8.9 9.1 9.5 9.9 9.8 9.5 10.0 10.4 10.5 10.5 10.5 10.4 10.0 9.6 9.3 8.9 8.6 8.5 8.1 7.8 7.5 7.5 8.1 9.0 9.1 8.9 8.1 7.4 7.5 7.4 6.8 7.0 6.6 8.5 8.5 10.0 9.8 9.0 7.9 7.3 7.0 6.9 6.6 6.6 6.6 6.6 7.0 7.4 7.4 8.1 8.3 8.8 9.5 10.1 10.4 10.5 10.4 9.3 8.8 8.4 7.9 7.3 6.9 6.8 6.4 6.1 6.4 6.5 7.5 8.4 8.5 7.5 6.5 8.4 8.0 7.3 8.3 7.0 6.3 6.9 8.6 8.9 9.8 9.8 8.9 9.4 9.5 8.8 9.0 8.5 8.0 7.3 7.5 8.4 8.4 7.4 8.1 9.5 10.1 10.3 10.4 10.4 8.0 7.8 7.3 7.0 6.6 6.5 6.3 5.9 5.8 5.8 5.8 6.0 6.9 8.5 6.9 6.1 7.3 8.1 6.6 6.5 6.4 6.4 6.9 8.6 9.0 9.0 9.0 8.4 8.9 8.8 8.0 7.6 7.0 6.8 6.9 7.3 7.0 6.5 7.4 8.3 8.8 8.9 9.1 9.5 9.8 6.9 6.8 6.4 6.0 6.8 7.1 7.4 7.0 5.6 5.4 5.3 5.8 5.9 8.1 7.8 6.6 6.1 8.0 8.1 8.0 7.9 7.8 7.0 6.5 6.6 6.5 6.6 6.5 6.4 6.4 6.1 6.4 6.8 6.5 6.4 6.5 6.3 6.5 7.0 6.9 7.0 7.3 7.6 8.0 8.4 6.8 6.0 5.8 5.6 6.6 7.1 7.4 7.3 6.1 5.3 5.1 5.5 5.9 8.5 9.3 9.4 9.1 9.0 9.1 9.0 8.9 8.6 7.9 8.4 8.5 8.4 8.4 8.3 8.0 7.9 7.6 8.1 7.8 6.9 7.5 8.0 7.3 7.3 7.3 6.5 6.4 6.5 6.6 6.6 7.0 7.3 6.4 5.8 5.5 5.8 6.4 6.6 6.3 5.5 5.3 5.0 5.1 6.0 8.8 11.0 11.1 10.5 7.5 7.5 7.5 7.4 7.3 6.8 7.6 7.9 7.8 7.8 7.6 7.6 7.5 7.4 7.5 7.3 6.8 7.4 7.5 7.0 7.1 6.9 6.4 6.1 6.1 6.1 6.0 6.5 6.4 6.0 5.5 5.0 4.8 5.5 5.9 5.6 5.4 4.6 4.8 5.3 6.0 7.9 10.4 11.0 11.0 8.0 5.8 5.5 5.5 5.4 5.3 5.1 5.4 5.4 5.6 5.5 5.5 5.4 5.4 5.8 5.9 5.8 6.1 6.3 6.6 6.5 6.0 6.0 5.6 5.5 5.4 5.4 5.6 5.6 5.1 4.8 4.9 5.4 5.4 6.0 5.9 5.8 5.4 5.1 5.6 6.0 7.0 8.3 9.6 9.8 7.1 5.0 5.0 4.9 5.0 5.0 4.4 4.8 5.3 5.5 5.1 5.4 5.3 4.9 5.1 5.4 5.1 5.6 5.3 5.5 5.4 5.5 5.4 5.5 5.4 5.4 4.9 5.5 5.8 5.1 5.3 5.5 6.1 6.1 6.3 6.3 5.9 5.8 5.4 5.9 6.4 6.9 8.8 10.5 10.6 8.1 5.4 5.0 5.5 5.9 5.8 5.3 5.0 5.4 6.3 6.4 6.5 6.3 5.8 5.6 5.5 5.3 5.4 5.4 5.5 5.5 5.5 5.6 5.5 5.6 5.4 5.8 6.1 6.1 5.3 5.4 5.5 6.3 6.9 7.0 6.8 6.3 5.9 5.8 6.3 6.4 8.9 10.5 10.8 10.8 8.8 6.0 5.3 5.4 5.5 6.9 5.5 5.8 6.5 7.3 7.4 7.4 7.4 7.3 7.0 6.0 5.4 6.3 6.1 5.9 6.3 5.8 5.6 5.8 5.6 5.8 6.1 5.9 6.4 5.4 5.5 5.6 5.6 6.0 6.0 5.9 5.8 6.1 5.6 5.8 6.5 10.1 10.8 10.9 10.9 9.5 6.8 5.0 5.3 6.3 6.5 5.8 6.1 6.0 5.6 5.6 5.5 5.8 5.5 6.6 6.0 5.8 6.5 6.8 6.8 6.8 5.9 5.9 5.8 6.0 6.4 6.3 6.3 7.3 6.3 5.9 5.0 5.0 5.1 5.1 4.5 4.8 4.9 5.9 6.5 8.5 10.6 10.8 10.9 10.9 10.3 6.5 5.3 6.1 7.9 6.9 6.3 5.9 5.9 7.9 8.0 8.0 8.0 7.9 7.4 6.0 6.0 5.6 5.9 5.6 5.5 5.5 5.8 5.6 5.8 5.6 6.0 6.5 8.0 7.6 6.5 5.1 5.3 5.9 6.1 5.5 4.9 4.8 5.9 6.8 8.9 10.5 10.8 10.8 10.8 10.6 7.1 6.4 6.0 6.6 6.0 5.4 5.9 7.0 10.4 10.5 10.5 10.5 10.3 10.4 10.0 9.8 9.6 9.6 9.4 8.8 8.8 8.9 8.8 8.8 8.8 8.9 9.0 9.5 9.4 8.1 6.8 5.5 4.8 4.6 5.0 5.4 5.5 6.0 6.9 8.9 10.5 10.6 10.6 10.8 10.6 8.9 6.3 5.1 6.6 6.5 5.8 5.4 7.0 10.3 10.6 10.6 10.6 9.9 9.6 9.6 9.5 9.3 9.4 9.1 8.3 9.6 10.0 9.6 9.3 9.3 9.3 9.1 9.8 9.5 8.8 7.4 6.1 5.5 6.0 5.8 6.3 6.3 6.3 6.8 9.1 10.4 10.5 10.6 10.6 10.6 9.6 6.5 6.0 6.4 6.5 6.3 6.1 7.0 8.9 10.5 10.5 10.5 9.3 5.6 5.3 5.1 5.1 5.3 5.3 7.3 9.6 9.9 9.1 7.6 7.3 7.3 7.6 9.6 9.6 9.3 7.8 7.1 7.5 7.6 7.6 6.8 6.3 6.4 7.1 9.8 10.4 10.5 10.5 10.5 10.6 10.1 6.8 6.5 6.5 6.5 6.8 6.6 6.8 8.9 10.4 10.4 10.5 9.3 5.4 5.0 4.8 5.3 4.4 5.3 6.5 9.0 9.8 9.4 8.6 8.6 8.4 8.3 9.4 9.5 9.5 8.8 7.3 5.8 5.8 4.9 5.5 6.4 6.8 8.6 10.1 10.4 10.4 10.5 10.5 10.4 10.3 7.4 6.8 6.8 6.6 6.6 6.8 6.8 9.4 10.3 10.4 10.4 9.6 6.1 5.3 4.9 5.0 5.1 4.4 6.1 8.5 9.6 9.4 8.6 8.6 8.4 7.9 9.3 9.4 9.5 9.4 8.3 6.1 5.5 5.5 6.3 7.1 8.4 9.8 10.3 10.3 10.3 10.4 10.4 10.4 10.4 9.3 6.6 6.6 6.6 6.8 6.9 7.1 9.1 10.3 10.3 10.3 9.9 6.8 5.6 5.1 5.4 5.3 5.4 6.3 8.4 9.6 9.5 8.6 8.6 8.4 7.8 9.1 9.4 9.4 9.4 9.3 9.0 9.3 9.5 9.6 9.9 9.9 10.0 10.1 10.3 10.3 10.3 10.3 10.3 10.3 9.9 8.6 8.6 8.9 9.3 9.4 9.6 10.0 10.3 10.3 10.1 10.1 8.4 9.0 8.9 8.8 8.9 8.8 8.8 8.9 9.4 9.4 8.6 7.9 7.8 7.4 9.1 9.3 9.4 9.4 9.5 9.5 9.6 9.8 9.9 9.9 10.0 10.0 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.0 10.1 10.1 10.1 10.3 10.1 10.1 10.1 10.1 10.1 10.0 10.0 10.0 9.9 9.9 9.8 9.4 9.3 9.3 9.0 8.3 6.4 5.5 6.1 9.1 9.1 9.3 9.3 9.4 9.5 9.5 9.8 9.8 9.9 9.9 10.0 10.0 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.1 10.0 10.0 10.0 9.9 9.8 9.8 9.4 7.1 5.9 5.8 5.5 5.1 4.4 3.5 5.3 9.0 9.0 9.1 9.3 9.4 9.4 9.5 9.6 9.6 9.8 9.8 9.9 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.1 10.1 10.0 10.0 10.0 10.0 9.9 9.9 9.8 9.8 9.8 9.0 6.3 5.4 4.4 3.9 3.3 4.3 4.4 4.8 9.0 8.9 9.1 9.1 9.3 9.4 9.5 9.5 9.6 9.6 9.8 10.1 10.1 10.1 10.1 10.0 10.0 10.0 9.9 10.0 9.9 10.0 10.0 9.9 10.0 10.0 10.0 10.0 10.0 10.0 10.3 10.3 10.1 10.0 9.8 9.8 8.9 7.4 6.0 5.3 5.4 4.9 4.9 3.1 5.1 8.9 9.0 9.0 9.1 9.1 9.3 9.4 9.4 9.4 9.6 9.8 9.8 9.8 9.8 9.8 9.9 9.9 9.9 9.9 9.9 9.9 9.9 9.8 9.9 9.9 9.9 9.9 9.9 10.0 9.9 9.9 9.9 9.9 9.8 9.6 9.8 8.9 6.9 5.8 5.0 4.1 4.8 2.3 2.8 4.8 8.9 9.0 9.0 9.1 9.3 9.3 9.3 9.4 9.4 9.6 9.6 9.6 9.6 9.8 9.6 9.8 9.8 9.8 9.8 9.8 9.8 9.8 9.8 9.9 9.9 10.0 10.0 9.9 9.9 9.9 9.9 9.9 9.8 9.8 9.8 9.6 9.1 7.0 5.3 4.4 4.8 5.1 4.1 4.4 5.0 8.8 8.9 8.9 9.0 9.0 9.1 9.3 9.4 9.4 9.4 9.5 9.5 9.5 9.6 9.5 9.6 9.6 9.6 9.6 9.6 9.8 9.6 9.6 9.6 9.8 9.8 9.6 9.6 9.8 9.8 9.6 9.6 9.6 9.6 9.6 9.6 9.3 7.5 6.0 5.6 4.9 5.3 4.1 4.6 2.3 8.8 8.8 9.0 8.9 8.9 9.1 9.1 9.3 9.3 9.4 9.3 9.4 9.4 9.4 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.5 9.6 9.6 9.6 9.6 9.6 9.6 9.6 9.6 9.5 9.6 9.5 9.4 9.1 7.6 5.8 5.0 5.1 5.6 3.6 4.9 5.3 8.6 8.8 8.8 8.8 9.0 9.0 9.1 9.0 9.1 9.1 9.3 9.3 9.4 9.3 9.4 9.4 9.4 9.4 9.4 9.5 9.5 9.5 9.5 9.5 9.6 9.4 9.4 9.5 9.4 9.5 9.5 9.5 9.5 9.4 9.3 9.4 9.0 7.9 5.9 5.6 4.5 4.4 4.1 4.4 5.0 8.4 8.8 8.8 8.6 8.9 8.9 9.0 9.0 9.0 9.1 9.3 9.0 9.1 9.3 9.1 9.1 9.3 9.4 9.4 9.4 9.3 9.4 9.4 9.4 9.5 9.5 9.4 9.4 9.4 9.4 9.5 9.5 9.4 9.4 9.4 9.3 8.9 8.4 6.1 5.1 3.6 5.6 5.4 6.1 6.4 7.6 7.9 7.9 7.9 8.0 8.3 8.6 8.6 8.5 8.9 8.1 7.9 8.0 8.0 8.0 8.4 9.1 9.8 11.1 11.3 9.9 9.4 8.5 7.4 7.3 8.1 8.5 9.9 9.6 9.8 10.4 10.4 9.9 9.4 9.0 8.8 8.6 8.8 9.0 8.0 7.9 7.8 7.8 8.1 7.8 7.6 8.0 8.4 8.8 9.3 9.3 9.0 9.1 9.1 9.9 10.1 8.6 8.9 8.8 10.4 10.8 9.6 8.9 9.1 8.5 9.3 6.8 8.6 6.9 7.3 7.1 7.9 8.1 8.5 8.5 9.3 9.3 9.3 9.8 9.9 9.5 9.6 9.0 9.3 8.8 8.1 7.9 7.8 8.3 7.6 8.0 8.6 8.5 8.8 9.4 9.5 10.0 9.9 9.5 9.3 9.9 9.3 8.4 7.5 8.9 9.4 6.9 7.0 9.0 6.9 9.4 10.0 10.3 7.6 7.8 6.9 6.8 7.8 6.6 6.3 7.8 5.8 8.1 6.8 9.3 7.9 6.9 7.9 10.0 8.6 7.0 7.4 7.6 7.9 8.0 8.4 9.0 9.1 9.4 9.5 9.3 9.0 9.1 9.0 9.6 9.4 9.6 9.3 6.3 9.4 9.8 9.8 8.3 9.4 9.3 9.1 9.1 9.6 7.9 8.3 8.8 8.6 9.4 8.3 8.8 9.6 9.1 9.6 9.4 9.0 8.9 9.3 9.6 9.3 8.4 8.6 8.9 8.6 8.1 8.1 9.5 9.0 9.3 9.9 9.5 8.8 8.1 8.1 9.5 9.5 9.4 9.6 10.0 7.5 9.0 9.1 9.5 7.6 7.5 7.8 7.9 8.0 8.9 9.1 9.3 9.1 9.1 9.4 9.5 9.3 9.3 9.0 9.0 8.9 9.3 9.4 9.5 9.4 9.0 9.5 9.6 9.1 9.4 8.8 8.4 9.0 9.8 9.5 9.6 9.4 8.5 8.4 8.4 9.1 9.4 9.6 9.3 9.5 8.1 7.3 7.3 6.8 7.4 7.6 7.8 7.9 7.9 8.5 7.4 7.4 7.3 7.3 7.8 7.6 7.6 8.3 7.0 8.6 8.9 8.4 7.4 9.5 8.5 8.3 9.5 9.0 9.4 9.4 9.5 9.1 8.6 9.1 9.5 9.6 9.4 8.6 9.0 9.1 9.5 9.4 9.6 9.5 9.6 9.9 7.4 7.5 7.4 10.0 9.3 9.1 9.1 9.4 9.5 8.5 8.6 8.9 8.5 8.6 8.9 8.6 8.8 8.5 9.1 9.4 8.6 8.1 9.0 8.8 8.9 9.5 9.4 9.6 8.9 9.6 9.5 9.3 9.4 9.1 9.3 9.6 9.4 9.4 9.5 9.1 9.9 9.8 9.6 9.3 10.4 7.9 7.9 7.3 9.5 9.6 9.6 9.5 9.3 9.5 9.5 9.5 9.5 9.5 9.5 9.6 9.8 9.6 9.1 9.4 9.5 9.1 9.5 8.8 9.1 9.3 9.3 9.5 9.1 9.3 9.8 8.9 9.1 9.6 9.8 9.5 9.5 9.5 9.5 9.3 9.4 9.3 9.5 9.3 9.5 9.3 8.8 8.3 7.9 10.3 9.8 9.8 9.8 9.6 9.4 9.6 9.4 9.4 9.5 9.4 9.3 9.3 9.4 9.4 9.5 9.5 9.1 9.9 9.5 9.9 9.5 9.5 9.5 9.4 9.8 10.0 9.4 9.4 9.6 9.6 9.0 9.3 9.0 9.5 8.9 9.0 9.1 9.4 9.0 8.9 9.0 8.5 7.1 7.0 8.1 9.4 9.4 9.3 8.8 9.1 9.4 9.4 9.3 8.9 8.8 8.8 9.1 9.4 9.1 9.5 9.4 9.3 9.1 9.3 9.8 9.3 9.4 9.5 9.4 9.4 9.0 9.8 9.4 9.8 9.4 10.0 9.6 9.0 8.6 8.5 8.8 9.4 9.3 9.3 9.5 8.4 7.5 7.6 7.5 8.1 9.5 9.6 9.6 9.0 8.5 9.3 9.1 8.9 8.4 8.5 8.6 8.5 8.4 8.5 9.5 9.5 8.8 9.4 9.3 9.0 9.5 9.4 9.8 9.9 9.4 9.0 9.4 9.8 9.9 9.3 9.0 9.9 9.4 9.6 9.1 9.6 9.1 9.5 9.8 10.1 7.9 7.9 7.8 7.8 8.0 8.6 9.6 9.5 9.3 9.3 9.4 9.1 9.4 9.3 9.4 9.3 9.5 9.8 9.0 9.3 9.9 8.9 8.9 9.1 8.9 9.3 9.6 9.8 9.5 8.8 9.4 9.8 8.9 8.9 8.9 9.9 10.0 10.3 9.6 9.8 9.8 10.0 9.5 9.1 9.0 7.6 7.9 7.8 8.0 7.6 9.5 9.9 9.3 8.9 9.0 9.4 9.5 9.0 7.5 7.1 7.1 7.4 7.8 8.4 9.1 9.3 9.6 9.1 9.6 9.3 9.6 9.4 9.6 9.5 9.5 9.5 9.4 8.9 8.9 8.9 9.1 9.5 9.5 9.1 9.0 9.6 9.5 9.6 8.6 8.9 7.6 7.9 7.9 7.9 7.6 8.6 9.1 9.4 8.8 9.5 9.3 9.3 8.4 7.5 7.8 7.8 7.6 7.9 7.5 7.5 7.5 7.4 7.4 7.6 8.1 7.9 7.3 7.6 7.6 7.4 7.3 7.3 7.8 7.6 7.5 9.0 9.8 9.9 9.8 10.0 9.1 9.6 8.9 8.5 8.9 7.8 7.9 7.6 7.9 7.8 8.3 9.4 9.4 9.3 9.4 9.4 9.1 8.8 7.9 8.0 7.8 7.9 8.5 8.0 8.4 8.4 8.9 8.3 8.4 10.6 7.1 7.9 7.9 8.3 7.8 7.8 7.9 7.5 8.0 8.6 8.1 9.6 9.3 9.0 9.4 8.5 9.1 9.4 8.6 8.4 7.8 8.0 8.0 7.9 7.9 7.6 8.9 9.5 8.6 8.8 8.6 9.1 8.6 7.6 7.6 7.9 7.8 8.5 10.0 9.8 9.5 9.3 9.4 10.3 9.9 7.3 7.6 8.8 9.6 9.1 9.8 8.8 7.6 7.1 6.3 8.3 8.9 8.0 8.4 8.0 8.6 9.3 8.9 8.5 7.6 7.8 7.9 8.0 8.0 7.8 7.6 8.8 8.4 8.9 9.0 9.0 9.1 9.0 7.3 7.9 7.9 7.6 8.4 9.1 9.8 9.6 9.9 9.5 9.5 9.8 7.6 7.5 8.5 8.5 7.5 7.8 7.8 8.0 7.6 7.3 7.8 9.5 8.9 9.8 9.3 9.1 9.5 8.1 8.1 7.9 8.0 7.9 7.8 7.8 8.0 7.8 9.1 9.0 8.3 8.6 9.1 9.0 8.6 7.4 7.8 7.8 8.0 8.4 9.6 9.8 9.6 9.5 9.6 10.1 9.8 7.1 7.5 7.9 8.9 8.0 7.6 8.6 8.0 7.8 7.4 7.5 7.8 9.5 10.1 9.8 9.0 9.4 8.0 7.8 7.8 8.1 8.0 8.0 7.6 7.9 7.8 7.8 9.1 8.6 9.0 8.9 8.8 7.9 7.6 7.8 8.1 7.9 8.0 9.5 9.9 9.3 9.3 9.1 9.6 9.9 7.3 7.6 7.9 9.0 8.1 8.6 9.0 8.4 7.9 8.0 8.0 7.6 7.8 7.6 7.6 7.5 7.6 7.9 8.3 8.0 7.8 8.1 7.6 7.5 8.0 8.3 7.6 7.3 7.3 6.9 7.1 7.1 7.3 7.6 7.9 7.9 8.0 7.8 7.9 7.1 7.4 7.8 7.8 7.3 7.9 7.8 7.4 7.9 9.1 8.8 9.0 8.6 7.9 7.8 8.0 8.0 8.3 7.4 7.8 8.3 8.1 8.0 7.8 7.8 8.0 8.0 7.8 8.0 8.0 7.9 8.0 7.8 7.6 8.3 7.8 7.8 7.6 7.9 7.6 7.8 7.9 7.9 7.9 8.0 7.8 7.6 8.0 7.9 7.8 7.9 8.3 7.9 8.0 8.5 9.8 10.6 10.0 7.3 7.5 8.0 8.0 8.6 8.3 8.1 7.4 7.4 7.4 7.8 8.0 7.6 8.1 7.3 7.6 7.4 7.6 8.0 7.8 7.6 8.0 7.5 7.6 8.0 7.5 7.6 7.8 7.5 8.0 7.6 7.8 7.6 7.5 7.8 7.6 7.5 10.5 10.3 9.4 10.4 9.9 9.5 9.8 9.5 8.6 8.0 8.6 8.4 8.1 7.8 8.1 8.3 7.9 7.9 8.0 7.9 7.8 7.5 7.8 8.0 7.8 7.5 7.8 7.8 7.9 7.9 7.6 8.0 7.9 7.5 7.6 7.8 7.8 8.0 7.9 7.5 7.9 7.8 8.1 8.0 7.9 10.6 10.5 9.5 10.8 10.5 10.0 9.5 9.6 8.0 7.5 8.3 8.0 8.0 7.3 8.0 7.4 7.9 7.6 7.5 7.5 8.1 7.8 7.6 8.0 8.1 7.6 7.9 8.0 7.6 7.6 7.5 8.0 8.0 7.5 7.6 8.0 7.5 8.0 7.6 7.9 7.9 7.5 7.5 7.3 7.6 10.1 9.6 9.3 10.5 10.0 9.8 9.6 9.1 8.1 8.0 8.1 6.9 7.6 7.6 6.6 8.0 7.5 6.9 7.6 7.9 8.1 7.9 7.6 7.9 7.0 7.5 7.6 8.3 7.5 8.0 7.8 7.6 7.6 7.9 7.6 7.6 7.3 7.8 7.6 7.4 7.1 7.5 7.9 7.9 8.1 8.3 8.3 9.3 10.4 9.3 9.8 9.8 9.8 8.3 8.1 8.5 7.6 8.3 8.1 8.1 8.3 8.4 7.3 7.6 8.1 8.3 7.4 8.3 8.1 7.6 7.4 7.8 8.3 7.5 7.9 7.6 7.8 7.5 7.8 7.6 7.8 7.3 7.4 7.6 7.9 8.1 8.3 7.9 7.6 8.4 10.8 10.0 12.4 10.1 9.3 11.4 10.1 9.8 7.0 7.4 7.8 8.9 8.1 8.1 8.0 7.5 7.5 7.4 8.1 7.1 8.5 7.5 7.8 7.9 7.5 8.0 7.8 7.9 7.5 7.3 8.0 7.0 8.1 7.8 7.6 7.8 7.5 7.3 8.3 8.0 8.1 7.6 7.5 7.6 7.9 11.3 10.8 9.3 10.1 9.4 11.3 10.8 10.8 7.6 7.5 7.5 7.9 8.8 7.6 7.9 8.3 7.6 7.8 8.3 8.1 7.3 7.4 8.0 8.0 7.9 8.0 8.0 8.1 8.0 7.4 7.9 8.0 8.1 7.5 8.3 7.9 8.1 8.0 7.8 7.6 8.3 7.3 8.4 8.4 7.3 8.9 10.9 8.9 9.4 8.8 9.6 9.6 9.0 8.3 7.8 8.3 7.3 7.0 7.6 7.3 7.4 7.5 8.6 7.1 7.3 8.3 8.3 8.0 7.0 8.0 8.3 7.4 8.5 7.9 7.8 8.0 7.9 7.0 7.4 7.8 7.4 8.3 7.6 7.6 8.1 8.4 8.4 7.4 7.8 8.4 9.3 9.9 10.8 12.4 10.1 9.6 12.4 8.8 6.6 6.9 6.8 10.1 8.3 7.8 7.1 6.5 5.6 7.8 7.8 7.6 7.5 6.5 7.8 8.0 7.8 7.6 8.0 7.4 7.4 8.0 7.3 8.0 7.6 7.8 8.1 8.3 7.0 8.1 7.9 7.5 7.6 7.0 8.1 8.9 7.4 6.6 9.6 10.3 9.1 9.4 9.4 9.4 11.8 11.6 11.5 11.8 11.4 11.5 11.4 11.3 11.0 10.8 10.8 11.4 11.5 11.4 11.4 11.4 11.3 10.8 10.1 8.9 9.8 10.3 11.1 12.4 12.5 11.9 11.8 11.5 10.4 10.6 10.6 9.9 9.9 10.3 10.4 10.9 11.0 11.1 11.0 11.0 11.6 11.8 11.5 11.4 11.4 11.5 11.6 11.5 11.3 11.1 10.6 10.4 10.5 10.5 10.4 10.1 10.1 11.4 11.0 11.1 9.9 9.8 10.8 11.0 11.1 10.9 10.9 12.4 10.6 12.1 11.9 11.8 11.8 12.0 11.1 11.4 10.8 10.8 10.5 10.8 10.4 10.6 11.6 11.0 10.5 11.1 11.5 11.6 11.5 11.3 11.5 11.5 11.3 10.9 11.0 10.5 10.0 9.8 10.3 10.1 10.4 10.1 10.6 11.1 11.9 10.8 10.6 12.0 12.9 10.8 12.8 10.6 10.0 9.9 11.8 11.6 11.9 12.3 11.4 12.0 12.4 11.4 12.9 11.1 12.6 10.5 12.5 12.1 11.0 9.8 11.4 12.1 11.9 11.5 11.4 11.3 11.3 11.0 10.5 10.4 10.4 10.1 10.6 10.5 10.5 10.5 10.5 10.3 10.9 12.4 10.3 10.4 9.6 11.4 10.5 10.6 10.5 10.6 10.1 11.3 11.3 10.5 11.0 10.6 11.3 10.6 10.1 10.4 10.1 10.5 10.8 10.6 10.5 10.6 10.5 11.4 10.9 10.8 11.1 11.3 11.4 10.4 10.5 10.5 9.8 10.3 11.4 11.3 11.5 10.3 10.1 10.1 10.3 10.0 12.0 10.1 10.6 10.5 11.5 11.6 11.5 11.6 11.6 10.9 10.6 10.5 10.6 10.4 10.5 10.5 10.5 10.5 10.6 10.5 10.8 10.5 10.6 10.4 10.8 10.6 10.3 10.0 10.3 10.5 11.0 11.3 10.8 10.5 10.5 10.1 10.3 10.9 11.1 11.3 10.8 10.3 10.3 10.0 10.0 11.0 11.4 11.5 12.3 11.9 11.6 11.8 11.6 11.6 11.3 11.9 12.0 11.9 11.8 11.6 11.8 11.9 11.5 12.0 10.9 11.0 11.5 11.9 10.5 11.0 11.3 10.1 10.8 10.4 10.3 10.5 10.9 11.4 10.1 10.0 10.4 10.3 11.0 10.6 10.4 10.5 10.1 10.0 10.4 10.4 9.9 11.6 11.5 11.5 11.1 10.9 10.8 10.5 10.8 10.1 11.3 11.3 11.4 11.3 11.3 10.9 11.1 11.1 11.3 10.6 10.4 11.3 11.6 10.8 11.0 10.8 10.3 10.4 10.5 10.5 10.4 10.3 10.9 10.5 10.4 10.5 10.3 10.1 10.4 10.5 10.1 10.3 10.1 10.3 10.5 10.0 11.8 11.5 11.6 11.1 10.3 10.4 10.3 10.4 10.3 10.5 10.4 10.4 10.4 10.4 10.4 10.4 10.3 10.8 10.5 10.5 10.5 10.4 11.3 11.0 10.5 10.4 10.4 10.8 10.6 10.4 10.6 10.6 10.3 10.5 10.5 10.3 10.4 10.6 10.5 10.3 10.1 10.3 10.6 10.5 10.6 11.3 11.1 11.5 10.6 10.1 10.3 10.4 10.3 10.5 10.4 10.3 10.4 10.3 10.5 10.4 10.5 10.4 10.3 10.4 10.5 10.3 10.1 10.5 9.9 10.5 10.6 10.1 10.4 10.0 10.1 10.3 10.4 10.0 10.0 10.4 10.1 10.6 10.9 10.8 10.5 10.5 10.3 10.6 10.5 10.5 11.0 11.8 11.8 11.8 10.4 10.3 10.5 10.4 10.5 10.3 10.0 10.5 10.8 10.8 10.8 10.8 10.4 10.5 10.1 10.1 10.1 10.4 10.3 10.3 10.5 10.0 10.1 10.3 10.4 10.0 10.1 10.1 10.0 10.1 10.1 10.6 10.5 10.6 11.4 10.9 10.3 10.3 10.5 10.4 11.0 11.6 11.6 11.6 11.5 10.3 10.1 10.0 10.4 10.5 10.5 10.5 10.8 11.1 11.1 11.3 11.0 11.3 10.9 10.1 10.3 10.4 10.1 10.3 10.6 10.1 10.1 10.4 10.0 10.6 10.4 10.6 10.5 10.4 10.5 10.5 10.5 10.9 10.5 10.5 10.5 10.8 10.3 10.3 10.6 11.5 11.5 11.5 11.5 11.6 10.9 10.3 10.1 10.6 10.9 10.4 10.5 10.5 10.5 10.3 10.5 10.4 10.3 11.3 10.3 10.3 11.1 11.3 11.0 11.1 10.8 10.6 10.5 11.1 11.0 10.6 9.6 10.5 10.3 10.3 10.5 10.0 10.1 10.0 10.4 10.1 10.0 10.5 10.5 10.8 11.6 11.6 11.5 11.5 11.6 11.0 10.3 10.5 10.8 10.9 10.4 10.4 11.0 11.3 11.6 11.6 11.9 11.3 11.1 10.5 10.0 10.3 10.3 10.1 10.6 10.3 10.0 10.1 10.1 10.6 10.3 10.1 10.6 10.0 10.5 10.6 10.1 10.5 10.6 10.0 10.0 10.1 10.3 10.6 11.1 11.5 11.5 11.5 11.5 11.4 12.5 10.6 10.5 11.1 10.5 10.4 10.3 12.3 11.5 11.5 11.5 11.5 11.6 11.6 11.5 11.4 11.3 11.5 11.1 10.6 11.4 11.1 11.5 11.3 11.0 11.1 11.6 11.5 11.8 11.8 10.4 10.4 10.0 10.5 10.4 10.8 10.0 10.4 10.9 11.1 11.6 11.5 11.5 11.5 11.5 11.8 10.4 10.5 10.5 10.6 10.4 10.4 11.5 11.5 11.4 11.5 11.5 11.5 11.5 11.4 11.3 11.0 11.3 11.4 9.5 12.0 11.4 11.5 11.4 11.3 11.4 11.6 11.5 11.8 11.4 10.4 9.9 10.8 10.3 10.4 10.6 10.5 10.3 11.1 11.4 11.6 11.4 11.5 11.5 11.5 11.8 11.0 10.5 10.6 10.9 11.0 10.1 11.1 11.9 11.5 11.5 11.5 11.5 10.0 10.3 10.4 10.4 10.4 10.1 9.5 11.9 11.6 10.8 10.4 10.3 9.9 10.9 11.5 11.9 12.1 11.4 9.6 10.4 10.9 11.3 10.4 10.9 11.0 10.9 11.4 11.5 11.5 11.5 11.5 11.4 11.5 12.0 11.3 10.8 11.3 10.3 11.1 11.3 11.9 11.5 11.8 11.5 11.4 10.3 10.5 10.3 9.9 10.5 10.0 10.0 12.1 11.6 11.1 10.9 11.8 11.4 11.0 11.5 11.3 11.8 11.9 10.0 11.0 10.5 10.6 10.6 10.9 10.6 11.4 11.5 11.5 11.5 11.5 11.5 11.6 11.6 11.9 11.0 11.0 11.0 10.8 10.9 11.4 11.5 11.5 11.6 11.5 11.4 10.4 10.0 10.0 10.3 10.1 10.3 9.4 11.8 11.9 11.3 10.9 10.9 11.3 11.0 11.5 11.6 11.6 11.9 11.4 10.4 10.4 10.3 10.5 10.8 11.1 11.5 11.5 11.5 11.6 11.5 11.5 11.6 11.6 11.8 11.1 11.1 11.1 10.9 10.8 11.9 11.6 11.6 11.8 11.5 11.4 10.9 10.0 10.4 10.5 10.8 9.9 10.3 11.8 11.8 11.5 10.9 11.5 11.4 11.1 11.6 11.5 11.5 11.6 11.5 11.4 11.3 11.6 11.5 11.5 11.6 11.5 11.5 11.6 11.5 11.8 11.6 11.6 11.4 11.6 12.0 11.8 11.6 11.8 11.8 11.9 11.5 11.4 11.5 11.5 11.4 11.5 11.5 11.8 11.6 11.6 11.6 11.5 11.3 12.0 11.5 10.4 11.1 11.1 11.1 11.4 11.5 11.4 11.4 11.4 11.4 11.6 11.5 11.5 11.5 11.5 11.6 11.4 11.5 11.6 11.6 11.6 11.6 11.5 11.5 11.6 11.5 11.5 11.6 11.6 11.4 11.5 11.5 11.5 11.6 11.5 11.4 11.6 11.5 11.3 11.5 11.5 11.8 11.4 11.6 11.5 11.6 9.9 10.5 9.8 11.6 11.6 11.4 11.6 11.5 11.5 11.6 11.6 11.6 11.6 11.6 11.3 11.6 11.5 11.5 11.5 11.6 11.6 11.5 11.6 11.6 11.5 11.8 11.5 11.5 11.6 11.4 11.4 11.5 11.5 11.6 11.5 11.6 11.6 11.6 11.6 11.8 8.9 9.6 10.1 9.9 10.0 10.4 10.5 9.3 11.5 11.3 11.0 11.0 11.3 11.9 11.4 11.4 11.5 11.6 11.5 11.8 11.6 11.5 11.3 11.5 11.5 11.8 11.6 11.8 11.5 11.5 11.6 11.4 11.8 11.6 11.5 11.8 11.5 11.5 11.4 11.5 11.4 11.8 11.3 11.6 11.4 9.8 9.9 10.4 10.0 10.4 9.9 10.3 10.9 11.3 12.0 11.8 11.5 11.6 11.9 11.1 11.5 11.4 11.8 11.8 11.5 11.3 11.3 11.4 11.4 11.5 11.5 11.6 11.5 11.8 11.8 11.6 11.6 11.6 11.9 11.4 11.4 11.6 11.5 11.4 11.0 11.0 11.4 11.5 11.8 10.8 10.4 10.1 10.1 10.4 10.4 10.1 10.9 10.8 11.8 11.0 11.5 11.6 11.8 11.6 11.6 11.5 12.0 11.4 11.5 11.5 11.4 11.8 11.8 11.3 11.5 11.6 11.6 11.5 11.6 11.8 11.9 11.8 11.9 11.8 11.5 11.6 11.6 11.6 11.8 11.6 11.6 11.8 11.5 11.5 11.3 11.6 11.6 10.4 10.0 10.5 10.9 10.5 9.5 11.3 11.9 11.8 11.4 11.0 11.4 11.6 11.8 11.4 11.4 11.4 11.5 11.6 11.6 11.8 11.3 11.6 11.6 11.8 11.6 11.8 11.9 11.8 11.5 11.8 11.4 11.6 11.9 11.9 11.6 11.8 11.6 11.8 11.5 11.5 11.9 11.5 9.3 10.3 10.0 10.8 10.1 10.1 11.3 9.6 11.8 11.0 11.3 11.4 11.1 11.5 11.6 11.4 11.4 11.6 11.1 11.4 11.3 11.5 11.5 11.6 11.6 11.5 11.5 11.5 11.6 11.5 11.3 11.5 11.5 11.8 11.6 11.9 11.6 11.4 11.6 11.6 11.4 11.5 11.4 11.8 11.4 9.1 9.6 9.3 10.4 9.8 9.8 9.9 10.1 11.6 12.0 11.0 11.3 12.0 11.8 11.6 11.0 11.9 11.4 11.8 11.4 11.8 12.0 11.3 11.6 11.6 11.9 11.9 11.4 11.9 11.9 11.9 11.6 11.5 11.8 11.8 11.9 11.6 11.6 11.6 11.5 11.5 11.6 11.8 11.9 11.9 12.0 10.8 11.5 10.0 10.9 10.9 9.4 10.5 11.3 11.9 11.9 11.9 11.9 11.4 11.6 12.1 11.8 11.5 11.6 11.9 11.4 11.6 11.5 11.8 11.8 11.5 11.8 11.5 11.6 11.5 11.8 11.8 11.5 12.1 11.9 11.8 11.8 11.5 11.8 11.8 11.5 11.5 12.1 11.8 12.0 11.8 10.4 11.1 10.3 10.5 10.3 9.6 11.8 11.9 11.6 11.5 11.8 11.9 11.8 11.9 11.9 11.9 11.5 11.8 11.9 11.8 11.4 11.6 12.1 12.0 11.6 11.5 11.9 12.4 11.9 11.9 11.6 12.0 11.9 12.1 11.9 11.8 11.9 12.0 11.6 11.3 12.1 11.5 11.8 12.5 11.6 9.9 10.8 12.3 10.9 9.4 10.5 9.1
Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Slave Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Manufacture Date : 2014:07:07
Production Code : 2.1
Internal Serial Number : 7050818
Power Source : Body Battery
Body Battery State : Full
Body Battery Voltage 1 : 6.71 V
Body Battery Voltage 2 : 6.46 V
AF Predictor : 903
AF Defocus : 2
AF Integration Time : 0 ms
Kelvin WB Daylight : 5205 0 2.216064453125 1.3848876953125
Kelvin WB 01 : 2500 0 1.202392578125 2.4937744140625
Kelvin WB 02 : 2630 0 1.2642822265625 2.388916015625
Kelvin WB 03 : 2780 0 1.33642578125 2.274658203125
Kelvin WB 04 : 2940 0 1.412841796875 2.16259765625
Kelvin WB 05 : 3130 0 1.5013427734375 2.0433349609375
Kelvin WB 06 : 3330 0 1.591064453125 1.9332275390625
Kelvin WB 07 : 3570 0 1.69287109375 1.8203125
Kelvin WB 08 : 3850 0 1.803466796875 1.710205078125
Kelvin WB 09 : 4170 0 1.91845703125 1.60693359375
Kelvin WB 10 : 4550 0 2.0401611328125 1.509033203125
Kelvin WB 11 : 5000 0 2.1658935546875 1.41845703125
Kelvin WB 12 : 5560 0 2.2982177734375 1.3326416015625
Kelvin WB 13 : 6250 0 2.430908203125 1.2542724609375
Kelvin WB 14 : 7140 0 2.5645751953125 1.1820068359375
Kelvin WB 15 : 8330 0 2.6959228515625 1.11572265625
Kelvin WB 16 : 10000 0 2.8211669921875 1.0552978515625
WB Shift AB : 0
WB Shift GM : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : 1 EV Steps
Serial Number : 6015692
Source Directory Index : 0
Source File Index : 0
Level Orientation : Horizontal (normal)
Composition Adjust : Off
Roll Angle : 4
Pitch Angle : -41
Composition Adjust X : 0
Composition Adjust Y : 0
Composition Adjust Rotation : 0
Contrast Detect AF Area : 0 0 0 0
Camera Temperature 2 : 18.7 C
Camera Temperature 3 : 18.7 C
---- PrintIM ----
PrintIM Version : 0300
---- Composite ----
Aperture : 4.0
Image Size : 1000x664
Lens ID : Sigma 18-250mm F3.5-6.3 DC Macro HSM
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/50
Thumbnail Image : (Binary data 4329 bytes, use -b option to extract)
Circle Of Confusion : 0.020 mm
Field Of View : 49.6 deg
Focal Length : 26.0 mm (35 mm equivalent: 39.0 mm)
Hyperfocal Distance : 8.44 m
Light Value : 5.0
---- File ----
Directory : .
File Size : 362 kB
File Type : JPEG
Image Width : 1000
Image Height : 664
Bits Per Sample : 8
---- JFIF ----
JFIF Version : 1.01
X Resolution : 300
Y Resolution : 300
---- EXIF ----
Y Resolution : 300
Artist :
Copyright :
F Number : 4.0
ISO : 1600
Exif Version : 0230
Color Space : sRGB
Contrast : High
Saturation : Normal
Sharpness : Hard
X Resolution : 300
Y Resolution : 300
Date : 2015:02:22
Time : 22:08:54
Quality : Best
F Number : 4.0
ISO : 2500
Saturation : Normal
Contrast : Med High
Effective LV : 5.3
Color Space : sRGB
Data Scaling : 8192
AE Lock : Off
Image Tone : Bright
Faces Detected : 0
Face Position : 0 0
Hue : Normal
Hometown DST : No
Contrast Shadow : 0
AF Adjustment : 0
Cross Process : Off
Aspect Ratio : 3:2
AE Aperture : 4.0
AE ISO : 2263
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Max Aperture : 3.9
AF Predictor : 903
AF Defocus : 2
WB Shift AB : 0
WB Shift GM : 0
Roll Angle : 4
Pitch Angle : -41
---- PrintIM ----
---- Composite ----
Aperture : 4.0
Light Value : 5.0
Posted 25/02/2015 - 03:25
OK, I've seen it now on the phone (EDIT and thanks for posting it too!) ..... there's a hell of a lot of data there, granted! Looking though initially we get the same sort of things I saw in PS ..... then there is those strange contrast / saturation/ sharpness fields that report 'High / Normal / Hard' (??) .... later there is some more on these , this time ' saturation - normal / Contrast - Med High / Sharpness - Med Hard' ... so I'm not sure about those .... we need to check the K3 manual to see if those descriptions are real (the previous models as we've seen use numerical values).
Then we have some Pentax specific data, which is great to see .... eg 'Image Tone - Bright' (thats a custom preset), 'Shake Reduction - On (AA Simulation Type 1)' / 'White Balance Auto Adjustment - Off' 'Tungsten AWB - Subtle Correction'.
So this is the most extensive collection of data I've seen outside of PDCU.
Then there a few custom paramaters, but I'm a little curious about these as they all show a 'O' value .... High/Low key adjust / Contrast Highlight / Contrast Shadow / Fine sharpness - Off'
Not sure about 'off' ... certainly on the K7 there is no Off, but rather a 0 setting in the middle .... and also the presets would have enabled different values for the individual sliders (they would not all be zero) .... so this is puzzling, but it may be we just need to know more about the K3 custom settings and how they differ from the earlier flagship models.
But, yes, Steve, absolutely .... there is a lot of good data there! Some contradictory and repeated, but I guess you could learn which ones to use reliably. I'm not sure on the custom settings values of zero though (???)
Thanks for showing that tool .... it seem to be be most comprehensive after PDCU itself, at least from what we've seen so far.
Posted 25/02/2015 - 05:39
Here's one of my 2013 K-7 files. Note there are two entries for sharpness. Under EXIF it is described as HARD the other (under makers notes) as +4.
It would seem to me that Pentax use both.
---- ExifTool ----
---- File ----
File Name : PENTAX K-7_IGP8793.dng
Directory : .
File Size : 11 MB
File Modification Date/Time : 2013:08:03 13:15:40+10:00
File Access Date/Time : 2013:08:13 11:19:50+10:00
File Creation Date/Time : 2013:08:13 11:19:50+10:00
File Type : DNG
MIME Type : image/x-adobe-dng
---- EXIF ----
Subfile Type : Reduced-resolution image
Image Width : 160
Image Height : 120
Bits Per Sample : 8 8 8
Compression : Uncompressed
Photometric Interpretation : RGB
Make : PENTAX
Camera Model Name : PENTAX K-7
Strip Offsets : 104416
Samples Per Pixel : 3
Rows Per Strip : 120
Strip Byte Counts : 57600
X Resolution : 300
Y Resolution : 300
Planar Configuration : Chunky
Software : K-7 Ver 1.12
Modify Date : 2013:08:03 13:15:38
Artist :
Subfile Type : Full-resolution Image
Image Width : 4736
Image Height : 3136
Bits Per Sample : 12
Compression : JPEG
Photometric Interpretation : Color Filter Array
Strip Offsets : 162016
Samples Per Pixel : 1
Rows Per Strip : 3136
Strip Byte Counts : 9992091
X Resolution : 300
Y Resolution : 300
CFA Repeat Pattern Dim : 2 2
CFA Pattern 2 : 2 1 1 0
CFA Layout : Rectangular
Black Level Repeat Dim : 2 2
Black Level : 0 0 0 0
White Level : 4095
Default Scale : 1 1
Default Crop Origin : 10 10
Default Crop Size : 4672 3104
Bayer Green Split : 0
Anti Alias Strength : 1
Image Width : 4672
Image Height : 3104
Compression : JPEG
Photometric Interpretation : YCbCr
Preview Image Start : 10154112
Rows Per Strip : 3104
Preview Image Length : 1183945
X Resolution : 300
Y Resolution : 300
White Point : 0.313 0.329
Primary Chromaticities : 0.64 0.33 0.21 0.71 0.15 0.06
Y Cb Cr Coefficients : 0.299 0.587 0.114
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Copyright :
Exposure Time : 1/125
F Number : 10.0
Exposure Program : Aperture-priority AE
ISO : 100
Date/Time Original : 2013:08:03 13:15:38
Create Date : 2013:08:03 13:15:38
Exposure Compensation : -3
Metering Mode : Spot
Focal Length : 300.0 mm
Exposure Mode : Manual
White Balance : Manual
Focal Length In 35mm Format : 450 mm
Contrast : Low
Saturation : Normal
Sharpness : Hard
Subject Distance Range : Distant
DNG Version : 1.1.0.0
DNG Backward Version : 1.1.0.0
Unique Camera Model : PENTAX K-7
Color Matrix 1 : 1.192230225 -0.5874328613 -0.06094360352 -0.6070251465 1.383773804 0.2443237305 -0.04161071777 0.07218933105 0.8370513916
Color Matrix 2 : 1.049530029 -0.3140869141 -0.1318054199 -0.6893463135 1.564834595 0.1210784912 -0.1703338623 0.2615814209 0.7600250244
Analog Balance : 1 1 1
As Shot Neutral : 0.5029469548 1 0.8421052632
Baseline Exposure : -0.5
Baseline Noise : 1
Baseline Sharpness : 1
Linear Response Limit : 1
Calibration Illuminant 1 : Standard Light A
Calibration Illuminant 2 : D65
Pentax Version : 6.0.0.0
Preview Image Size : 640x480
Preview Image Length : 20899
Preview Image Start : 34976
Pentax Model ID : K-7
Date : 2013:08:03
Time : 13:15:38
Quality : RAW
Focus Mode : AF-S (Focus-priority)
AF Point Selected : Fixed Center
F Number : 10.0
ISO : 100
Exposure Compensation : -3.0
White Balance : Cloudy
Saturation : Normal
Contrast : Very Low
Sharpness : +4
DSP Firmware Version : 1.12.22.28
CPU Firmware Version : 1.12.22.28
Effective LV : 10.6
Picture Mode : Aperture Priority; 1/3 EV steps
Drive Mode : Single-frame; Self-timer (2 s); Shutter Button; Single Exposure
Sensor Size : 28.704 x 19.070 mm
Color Space : Adobe RGB
Image Area Offset : 10 10
Raw Image Size : 4672x3104
Data Scaling : 8192
Preview Image Borders : 28 28 0 0
Lens Type : smc PENTAX-DA L 55-300mm F4-5.8 ED
Camera Temperature : 25 C
AE Lock : Off
Image Tone : Landscape
SR Result : Not ready
Shake Reduction : Off (4)
SR Half Press Time : 1.13 s
SR Focal Length : 284 mm
Shutter Count : 8856
Faces Detected : 0
Face Position : 0 0
Raw Development Process : 4 (K-7)
Hue : Normal
White Balance Auto Adjustment : On
Dynamic Range Expansion : Off; 0; 0; 0
Hometown DST : No
Hometown City : Sydney
Destination City : Sydney
High/Low Key Adj : -1
Contrast Highlight : 3
Contrast Shadow : 4
Contrast Highlight/Shadow Adj : On
High ISO Noise Reduction : Medium; Inactive; ISO>400
AF Adjustment : 6
Face Detect : Off; 0 faces detected
Shadow Correction : Off
ISO Auto Parameters : Fast
White Level : 4095
Black Point : 0 0 0 0
White Point : 16288 8192 8192 9728
Picture Mode 2 : Aperture Priority
Program Line : Normal
E-Dial In Program : Tv or Av
Aperture Ring Use : Prohibited
Flash Options : Red-eye reduction
Metering Mode 2 : Spot
AF Point Mode : Fixed Center
Focus Mode 2 : AF-S
AF Point Selected 2 : Center
ISO Floor : 100
Drive Mode 2 : Self-timer (2 s)
Exposure Bracket Step Size : 0.7
Bracket Shot Number : n/a
White Balance Set : Auto
Multiple Exposure Set : Off
AE Exposure Time : 1/121
AE Aperture : 9.9
AE ISO : 100
AE Xv : 3
AEB Xv : 0
AE Program Mode : Av, B or X
AE Aperture Steps : 11
AE Max Aperture : 5.9
AE Max Aperture 2 : 5.9
AE Min Aperture : 32
AE Metering Mode : [0], [1], [2], Spot
AE White Balance : Daylight Fluorescent
AE Metering Mode 2 : Multi-segment
Flash Exposure Comp. Setting : 0
Level Indicator : 255
Auto Aperture : On
Min Aperture : 32
Lens F Stops : 5.5
Nominal Max Aperture : 5.7
Nominal Min Aperture : 32
Max Aperture : 5.9
AE Metering Segments : 10.3 10.1 10.0 10.0 10.1 10.1 10.1 10.3 10.3 10.3 10.4 10.0 10.0 10.1 10.1 10.1 10.0 9.9 10.0 10.0 10.0 10.3 10.3 10.4 10.3 10.3 10.3 10.0 10.1 10.3 10.3 10.3 10.1 10.3 10.1 10.1 10.0 9.6 9.5 9.8 10.1 10.4 10.4 10.4 10.1 10.3 10.1 10.0 9.5 9.4 9.8 10.5 10.4 10.4 10.4 10.4 10.4 10.5 10.5 10.5 10.4 10.4 10.4 10.5 10.5 10.5 10.4 10.6 10.5 10.6 10.3 10.4 10.5 10.5 10.6 10.5 10.4
Manufacture Date : 2009:08:12
Internal Serial Number : 47246
Body Battery Voltage 1 : 7.00 V
Body Battery Voltage 2 : 6.61 V
AF Predictor : 6
AF Defocus : 4
AF Integration Time : 2 ms
AF Points In Focus : Center (vertical)
Kelvin WB Daylight : 5205 0 1.845703125 1.1773681640625
Kelvin WB 01 : 2500 0 1.0740966796875 2.350830078125
Kelvin WB 02 : 2630 0 1.1302490234375 2.21630859375
Kelvin WB 03 : 2780 0 1.192138671875 2.081298828125
Kelvin WB 04 : 2940 0 1.254638671875 1.956787109375
Kelvin WB 05 : 3130 0 1.324462890625 1.8306884765625
Kelvin WB 06 : 3330 0 1.3929443359375 1.7181396484375
Kelvin WB 07 : 3570 0 1.4691162109375 1.604736328125
Kelvin WB 08 : 3850 0 1.550048828125 1.49609375
Kelvin WB 09 : 4170 0 1.6331787109375 1.395263671875
Kelvin WB 10 : 4550 0 1.720458984375 1.2994384765625
Kelvin WB 11 : 5000 0 1.81005859375 1.2103271484375
Kelvin WB 12 : 5560 0 1.904296875 1.1253662109375
Kelvin WB 13 : 6250 0 1.9993896484375 1.04736328125
Kelvin WB 14 : 7140 0 2.095947265625 0.9747314453125
Kelvin WB 15 : 8330 0 2.1925048828125 0.9078369140625
Kelvin WB 16 : 10000 0 2.2872314453125 0.846923828125
WB Shift AB : 0
WB Shift GM : 0
Camera Orientation : Horizontal (normal)
Serial Number : 3405070
Roll Angle : 0.5
Pitch Angle : -18
WB RGGB Levels Daylight : 15031 8192 8192 11014
WB RGGB Levels Shade : 18016 8192 8192 8418
WB RGGB Levels Cloudy : 16326 8192 8192 9755
WB RGGB Levels Tungsten : 9206 8192 8192 20141
WB RGGB Levels Fluorescent D : 18987 8192 8192 10227
WB RGGB Levels Fluorescent N : 16110 8192 8192 11644
WB RGGB Levels Fluorescent W : 15031 8192 8192 14476
WB RGGB Levels Flash : 17405 8192 8192 9283
WB RGGB Levels Fluorescent L : 13233 8192 8192 18567
WB RGGB Levels User Selected : 15031 8192 8192 11014
---- Composite ----
Aperture : 10.0
CFA Pattern : [Blue,Green][Green,Red]
Image Size : 4736x3136
Lens ID : smc PENTAX-DA L 55-300mm F4-5.8 ED
Preview Image : (Binary data 1183945 bytes, use -b option to extract)
Preview Image : (Binary data 20899 bytes, use -b option to extract)
Shutter Speed : 1/125
Field Of View : 4.6 deg
Focal Length : 300.0 mm (35 mm equivalent: 450.0 mm)
Hyperfocal Distance : 449.31 m
Light Value : 13.6
---- ExifTool ----
---- File ----
Directory : .
File Size : 11 MB
File Type : DNG
---- EXIF ----
Image Width : 160
Image Height : 120
Make : PENTAX
X Resolution : 300
Y Resolution : 300
Artist :
Image Width : 4736
Image Height : 3136
Compression : JPEG
X Resolution : 300
Y Resolution : 300
White Level : 4095
Default Scale : 1 1
Image Width : 4672
Image Height : 3104
Compression : JPEG
X Resolution : 300
Y Resolution : 300
Copyright :
F Number : 10.0
ISO : 100
Contrast : Low
Saturation : Normal
Sharpness : Hard
Baseline Noise : 1
Date : 2013:08:03
Time : 13:15:38
Quality : RAW
F Number : 10.0
ISO : 100
Saturation : Normal
Contrast : Very Low
Sharpness : +4
Effective LV : 10.6
Data Scaling : 8192
AE Lock : Off
Faces Detected : 0
Face Position : 0 0
Hue : Normal
Hometown DST : No
Contrast Shadow : 4
AF Adjustment : 6
White Level : 4095
Focus Mode 2 : AF-S
ISO Floor : 100
AE Aperture : 9.9
AE ISO : 100
AE Xv : 3
AEB Xv : 0
Auto Aperture : On
Min Aperture : 32
Lens F Stops : 5.5
Max Aperture : 5.9
AF Predictor : 6
AF Defocus : 4
WB Shift AB : 0
WB Shift GM : 0
Roll Angle : 0.5
Pitch Angle : -18
---- Composite ----
Aperture : 10.0
Light Value : 13.6
Surrey,
England
We've seen confusing data reported by other members such as 'hard' settings for contrast and sharpness, 'normal' for metering mode. I do not see these descriptions as matching or relating to any Pentax camera settings, but there has been some debate about that! Also it was said that Photoshop will report all of the Pentax metadata.
So, just to round off this little diversion into the world of exif reporting in different programmes, I've loaded one of my K7 DNGs into Photoshop and also into Pentax Digital Camera Utility to compare the usefulness of the information .....
1) Photoshop ....
here I used the file menu, 'file info' option and this opens a dialogue with a group of sub-options on the left ... the botton of these is 'advanced', and this opens on the main part of the dialogue a number of sub-groups of data collections. The first of these is titles 'http://ns.adobe.com/camera-raw-settings/1.0/'
Here I find the following items of interest ....
Temperature 6050
Tint +15
Exposure +1.50
Shadows 25
Brightness 59
Contrast +48
Saturation 0
Sharpness 25
Now, none of these has much immediate significance to me.... apart from the colour temperature and exposure they don't equate to any obvious known direct camera settings .
Now, I have an old version of Photoshop, so I also opened the file in Photoshop Elements 8, which has a later version of Camera RAW (updated well after the K7 was released), and I found exactly the same settings as listed above for Phtoshop CS2 within the 'advanced' section. However, here in this later version of Photoshop Elements there is an additional 'Raw Data' tab within the file info dialogue, and here I found the following :
Contrast 1
Saturation 2
Sharpness 2
These clearly make more sense as camera settings, although this list of data did include a lot of other rather baffling fields, such as ' Exposure Mode 1, White Balance 1'.
Now the same DNG opened in PDCU ....
Here I have :
Metering Mode - Multi Pattern
White Balance - Daylight
Fine Tune AB - Amber 5
Exposure Compensation -1.0
Autofocus Mode - Single AF
Autofocus Area Mode - Automatic
Saturation - 1
Hue - 0
High / Low key adjust - -1
Contrast - -1
Contrast Highlight --2
Contrast Shadow - 1
Sharpness - 3
Fine Sharpness - 2
Shake Reduction - Enabled
Now clearly, this list is more what we need . These settings are directly a report of the actual camera settings using the exact same numerical values or word descriptions.
Even the three understandable photoshop values (contrast, saturation, sharpness) do not match the PDCU figures, and there is no further intelligible information amongst the jumble of data listed in the PS file info dialogue.
So, I can only conclude from this little test, that my earlier assertion that PDCU is the only programme to correctly report all of the Pentax camera settings is true .....
I can not find any meaning to much of the Photoshop file info, nor to the generic type like windows properties that reports things like 'hard' or 'normal'.
So, am I right ..... is the only way to get reliable and accurate data reporting from Pentax DSLRs to actually use PDCU ??
