Pentax DA 18-250mm vignetting
petemasty
Posted 14/01/2010 - 13:45 Link
Have just been taking some 'nice' forest pics in the misty weather here in sub-tropical Swindon. Got back home, and noticed considerable misty white/grey vignetting. i assume the 'whiteness' of the weather and of course the current landscape has accentuated the vignetting somewhat.
I'm just a little annoyed now because of the significant cropping i need to do. The shots are high contrast shots (dark trees, white ground, white sky). The two i quickly looked at were at f10 18mm.
Any thoughts? any recommendations on anything? eg, replacement lens, favourable focal lengths and f-stop settings?
Yours, in anticipation of a favourable reply.
PS, if it werent for the trees i think i would have suffered from snowblindness!!!
Pete M
My Flickr
iceblinker
Posted 14/01/2010 - 14:24 Link
Instead of cropping, you could lighten the corners with a program like Silkypix. This tends to effectively cure the problem.
Vignetting should not be bad at f10. Do you have a filter fitted? It could be too thick.
~Pete
Posted 14/01/2010 - 14:36 Link
Vignetting is a darkening of the corners, not a misty whiteness. To avoid confusion over what you are seeing, can you post an example?
Daniel Bridge
Posted 14/01/2010 - 15:15 Link
It sounds to me more like flare, but as John says, an example pic would help. Did you have the lens hood fitted? Snow can cause flare as easily as a very bright sky.
Dan
petemasty
Posted 14/01/2010 - 22:53 Link
Have uploaded a sample pic to my portfolio as I'm not sure how to stick on in here. It had an Ultra Slim UV filter on the front. Take a look and see what you think. No lens hood on it at the time
Pete M
My Flickr
Edited by petemasty: 14/01/2010 - 22:58
iceblinker
Posted 14/01/2010 - 23:14 Link
https://www.pentaxuser.com/photo/vignetting-example-13786/large
That's not normal vignetting because it is mostly light rather than dark.
Could it be condensation?
~Pete
petemasty
Posted 14/01/2010 - 23:24 Link
Just checked the lens and could find no condensation. Took a test shot just now and no discernable vignetting of any kind at f10 and 18mm.
I used the lens a few days ago in the same cold conditions and didnt get this effect, so somewhat perplexed. checked and cleaned the lens this moring before the shoot. no condensation before or after cleaning.
If anyone else has any idea as to what this could be then please feel free.
Pete M
My Flickr
Daniel Bridge
Posted 14/01/2010 - 23:29 Link
Did you have gloves on?
Dan
Posted 14/01/2010 - 23:49 Link
Gloves could explain it, but it's not vignetting. Maybe some condensation on the lens that evaporated after a while?
JonSchick
Posted 15/01/2010 - 09:02 Link
I agree - I think it's condensation that happened at the time the photograph was taken: all the more likely given that the situation does not appear to have recurred since.
Jon
Some occasional random stuff at The Photographers Block: link
mattox
Posted 15/01/2010 - 09:40 Link
What type of UV protector do you have on. I found with my 16-50 DA, in certain shots at 16mm vignetting was present with a standard UV. I went out and purchased a slim line UV filter made by hoya and haven't had the problem since.
JonSchick
Posted 15/01/2010 - 10:31 Link
It's not vignetting: that would be dark, and this sample isn't. It is an issue with the 18-250 though, but Pete has got a slim filter so he's done what he can to minimise (other than not have a filter at all).
Jon
Daniel Bridge
Posted 15/01/2010 - 10:32 Link
mattox wrote:
What type of UV protector do you have on?
I was wondering if Pete might have had white gloves on, they may have been enough to provide the whitish vignetting, if they were only just encroaching on the frame. Bit of a long shot though.
Dan
Daniel Bridge
Posted 15/01/2010 - 10:34 Link
Or perhaps he was wearing a see-through negligee that got caught in the wind, briefly obscuring the corners of the frame. That might do it...
Dan
petemasty
Posted 15/01/2010 - 10:51 Link
No see through negligee. Certainly not outdoors and in cold weather thats for sure!!!!! and realising the sort of minds out there I best not tell you what i have on under my jeans and jumper!!!!. No white gloves either. no gloves at all. Maybe it was a little bit of condensation. a mystery indeed!!
Thanks all. you may continue to speculate on this strange aberration.
Pete M
My Flickr
