Pentax Adapter
les
Posted 20/04/2008 - 11:49 Link
Hi ,
Has anybody heard of a Pentax bayonet to m42 male thread adapter, if so any info where to get one would be appreciated.
Mongoose
Posted 20/04/2008 - 12:05 Link
M42 lens to K body is easy and common, there are always loads of them on ebay, you just have to watch out for a few of the cheap knock off ones which loose infinity focus.
K lens to M42 body can't be done without either using an optical adaptor which functions as a short teleconverter, or loosing infinity focus. I believe both of these have been manufactured at one time or another, but they are rare and not overly useful.
but it does help
les
Posted 21/04/2008 - 07:30 Link
Thanks for the reply Mongoose,
By loosing infinity focus, is this because of the thickness of the adapter,if not why does this happen
Clarky
Posted 21/04/2008 - 08:58 Link
Yes, Some of the cheaper adapters have a flange on them and this causes the lens to sit proud of the mount. A better quality adapter will sit flush with the mount and allow you too achieve infinty focus
Camera:|K-7|
Mongoose
Posted 21/04/2008 - 10:00 Link
exactly correct. Unfortunately because the K mount is larger than M42, it is impossible to build a K lens to M42 body adaptor which sits flush to the mount.
I wasn't quite clear which way around you were looking for, so I thought I'd better describe both.
but it does help
Peter Bargh
Posted 25/04/2008 - 09:17 Link
Be very wary of the cheap ones.
It's easy to get the adaptor stuck in the camera.
A mini jeweller's screwdriver will help you remove it but take extra care that you don't catch the internal workings of the camera.
The Pentax version used to come with a special tool to remove the adaptor, I can't recall seeing one for a while.
Clarky
Posted 25/04/2008 - 09:27 Link
http://cgi.ebay.com.au/Pentax-ist-istD-K10D-K100D-ScrewMount-Lens-Adapter-NEW_W0QQitemZ290224310537QQihZ019QQcategoryZ30059QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This one i believe is the genuine article.
As peter says you don't see too many of them and it comes with the tool to insert and remove it.
Camera:|K-7|
