pentax a 50mm f2 query
Posted 04/02/2010 - 21:42
With the Pentax-A version, you need to leave the lens on the "A" setting to get full functionality with your camera. Notice the little unlock button you need to press to get it onto "A".
It's normal to display "F--" when the ring is off the "A" setting. The lens then can only be used in Manual mode (except for the largest aperture).
~Pete
Posted 04/02/2010 - 21:47
i have set the "A" part right over to the left hand side where i believe it should be for a function but it still says F--
Roye
Roye
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
Roy
my pbase gallery
Posted 04/02/2010 - 21:54
You need to turn the aperture ring all the way to the right (smallest aperture), then press the button next to the A and turn it a little further. You have to press the button before you can put it into or out of A mode.
I'm not sure if you have the A in the correct place. It should be at 12.0 clock on the lens and locked in by the button.
Barrie - Too Old To Die Young
Posted 04/02/2010 - 22:06
Clean the electrical contacts on the lens if you really have tried it on "A". I bet it isn't properly on though.
~Pete
Posted 04/02/2010 - 22:37
[IMG]http://i85.photobucket.com/albums/k59/iceblinker/Misc/P1010784.jpg[/IMG]
Notice the green mark directly lined up with the red mark.
~Pete
Posted 05/02/2010 - 10:31
hi
Thanks a lot, i had indeed set it wrongly.
Roy
Roy
regards
Roy
my pbase gallery
Roy
my pbase gallery
Newport,
South Wales,U.k
just purchased the above lens second hand (fleabay) the optics are fine very clear,but i have a question shouldnt i be able to set aperture in casmera for this lens? i know it is manual focus.
I have the camera set to use aperture ring "on" is there anything else i need to do as it just says F-- wherever i turn the aperture ring to!!!
Roy
Roy
my pbase gallery
