pentax A 35-70 f4
reso
Posted 10/02/2011 - 22:50 Link
i have been offered one for the price of the postage it has some lens separation but are told the body and all the other bits are all OK i have had a quote to fix £40 is the lens worth fixing ? or can it be you ed with out
Dangermouse
Posted 11/02/2011 - 00:00 Link
I'd be amazed if someone could fix separation for £40 - from what I understand this problem is caused by the breakdown of the glue used to cement elements together. At the factory the parts will be glued on very precise jigs in clean room conditions, both of which the average repairer will struggle to match. Unless the elements are precision glued to within a fraction of a millimetre the lens will be useless.
Smeggypants
Posted 11/02/2011 - 01:37 Link
Regarding the cementing of elements together ... I know bugger all about this so forgive a potential stupidquestion ...
but is the 'cement' transparent and applied across the whole area of the glass or is it just on the edges?
ManixZero
Posted 11/02/2011 - 05:18 Link
I also know nuffin about this myself but found this....
link
It seems that the adhesive is applied to the whole surface.
Cheerz
MZ
K5, K7, Nikon FA.
AF Lenses: DA15mm Ltd, DA21mm Limited, DA35mmAL, DA50mm f1.8, DA18-55mmWR, FA28-70mm f4AL, DA50-200mmWR,Tamron SP70-200mm f2.8, AF70-300mm LD Di, SP10-24mm, SP90mm Macro.
MF Lenses: SMC-A 50mm, Adaptall 24mm(CW-24), 135mm(03B), 35-70mm(17A) 80-210mm(03A), Micro-Nikkor55mm, Soligor I-S 200mm f2.8 AIS
My Flickr - link
My Photobucket - link
Algernon
Posted 11/02/2011 - 08:44 Link
Just get the lens and try it This is a really top lens and cement separation sometimes doesn't affect the pictures. In the meantime look out for a good one. Not worth paying for a repair that may not work. You should get a good lens for about £35 or less.
Oggy
Posted 11/02/2011 - 12:26 Link
I was watching a program about how lenses (not Pentax) were made. On that particular job, the lenses were cemented over their whole area.
