Interesting article on f1.4 versus f1.8
robbie_d
Link Posted 09/02/2011 - 14:25
Thought this might be of interest, given a recent thread was discussing the merits of f1.4 versus f1.8.
It centres around Canikon lenses but the general principle apply across brands.
link
Apparently.
Smeggypants
Link Posted 09/02/2011 - 14:59
Cheers. Interseting article.
The article is 'lab' based but then says ...
"The main reason I can see to invest in a 50mm f/1.4 is that the extremely narrow depth of field creates a very desirable effect that, in some circumstances, leads to a desirable look and feel that can’t be measured in the lab."
Which is exactly I bought an f1.2 and f1.4
robbie_d
Link Posted 09/02/2011 - 15:09
I know exactly where you're coming from Smeggy.
The lab can do many things but it can't measure the intangibles (Simga 30 f1.4 being the prime example).
Apparently.
Link Posted 09/02/2011 - 15:19
I find it dosconcerting that any writer can put "depth of focus" when he means "depth of field" but that aside, this is an interpretation of results from DxO so not original research.
However, the basic message is correct. F1.7/1.8 lenses perform better than the f1.4 versions, at least in certain parameters. If you use the f1.4 for what it is intended for then it becomes superior to the f1.7/1.8 versions.
robbie_d
Link Posted 09/02/2011 - 15:23
I wasn't aware I'd portrayed it as original research.
Apparently.
Link Posted 09/02/2011 - 15:28
Neither was I.
cameraboy
Link Posted 10/02/2011 - 15:51
k7 10-17fe 12-24 55 100 macro 18-55 50-200
cameraboy
Link Posted 10/02/2011 - 15:57
well said John where do these strange phrases come from i was always taught from books or friends DEPTH OF FIELD not depth of focus etc
petrochemist
Link Posted 10/02/2011 - 17:49
Depth of focus is a proper photography term, but it differs from depth of field.
IIRC It refers to the camera side of the lens, being the region in which the sensor/film can move without adversely affecting the results.
Link Posted 10/02/2011 - 18:17
Correct, there is a certain amount of depth of focus at the film/sensor plane. This allows for some error in the location of the film/sensor plane.
However, whereas smaller formats have more and more depth of field, they have less and less depth of focus. This means that smaller formats need higher standards of precision. This is where the 110 film cartridge and Kodak Disc formats fell down, with their cheap construction and tiny formats.
