Pentax 5P connector
Posted 13/11/2006 - 15:51
If you're handy with a soldering iron, snip the cable, and insert an extension with male and female plugs at the ends. Then you can use it short or long.
Posted 13/11/2006 - 16:13
I'm handy with a soldering iron
Just didn't really want to butcher my coiled lead - it's great when using the AF540-FGZ on a flash bracket. If I can get hold of compatible plugs, then I can make as many extension leads as I need
Posted 13/11/2006 - 21:33
Matt,
I had a look around for compatible plugs, and couldn't find any. I have four 5P leads, two short coils, one long coil, and one long straight.
If all else fails, PM me, and I will sell you a short coil for butchery.
24 years
Sussex,
UK
Does anyone know if the Pentax 5P connector is a standard connector of any sort? The reason for asking is that the standard coiled lead is far too short, and the 3m extension lead is rare & expensive.
If the K10D isn't going to support wireless P-TTL then I'm going to need a tethered solution for my two Pentax flashguns (or at least one tethered with the other being a wireless slave).
(I'm still trawling through all the component catalogues though...)
