Flash Compatibility
Jerry
Posted 04/11/2006 - 11:18 Link
Hi All,
I have a Pentax AF400FTZ I've been using on SFX's for years. In a recent conversation with a local shop I'm being told that it will not function with an *ist DL2, in fact it could apparently cause permanent damage.
Is this true? Do I have to get a new gun? A pity if so because this thing has been awesome for daylight fill in which is pretty much all I've used it for.
Jerry
stevieskin
Posted 04/11/2006 - 13:05 Link
The problem lies with the DL2 only having P-TTL flash compatability..
Your flash will work in manual mode, or auto if the flash has an inbuilt sensor. But you cannot use the TTL capabilities with the DL2.
As far as I know only the D & DS have TTL compatability.
Jerry
Posted 08/11/2006 - 23:28 Link
Ok, you got me now, what's 'P-TTL' mean please?
Looks like something else up for sale then!
Thanks foryour help
J
Mannesty
Posted 08/11/2006 - 23:37 Link
P-TTL = Pre-Flash TTL
Camera fires a pre-flash (seen through the viewfinder)
Camera metering works out correct flash configuration
Camera fires second flash to make the exposure
This is not the same as red-eye reduction.
fatspider
Posted 08/11/2006 - 23:48 Link
Never really thought about this but...
if the red eye is on will the flash fire three times in P-TTL mode?
or will the P-TTL use the red eye burst as a measure for the main flash?
My PPG link
My Flckr link
Posted 09/11/2006 - 09:17 Link
If you use P-TTL with red-eye there is just a longer gap between preflash and main flash.
i.e.
No red eye: Preflash, tiny-gap, Main flash
Red eye: Preflash, large-gap, Main flash
HTH!
