Pentax 50-200DA zoom - £122 Tecno
Posted 05/01/2007 - 20:15
Do Tecno still have shops? I wonder if there any "Up North". I 'll have to google them to find out.
HowardJ
HowardJ
Cymru Am Byth
Posted 06/01/2007 - 14:15
Howard
Don't know if there are still any Tecno shops around.
I used to visit the one in Birmingham but don't know if it's still there.
On line service was good though, only took two days.
6th Year Apprentice Pensioner
Posted 06/01/2007 - 15:32
SRS Microsystems are doing them for £129
Just got mine - what a diddy little lens
Now I need some light and subject to try it out
Posted 08/01/2007 - 20:06
I took delivery of the 50-200 today. But on inspection I thought the front element of the lens stood proud of the printed surround. I could rub my finger along the edge of the glass which was rough in some parts.
I got out my 18-55 to compare. And indeed on the 18-55 the glass is totally housed at the front with no exposed edge. Hope this is making sense.
I reboxed it, rang the supplier and asked them to look at another 50-200 while I was on the phone and they described it to be similar in finish to the smaller kit lens.
I'm thinking I got one with a factory fault. It's going back tomorrow for inspection. I'm hoping they will pay the post if I'm found to be correct.
Am I the unlucky one?
Tom
Tom
Posted 08/01/2007 - 20:38
Tom,
The front element is higher than the printed text. The actual construction is like this:
Printed area; small groove; metal ring; glass element that sits flush with the metal ring.
Hope that makes sense! Could do you a shot of mine if it'd help...
Posted 08/01/2007 - 20:48
Just took a quick snap of the front of mine, this is really close up so the rough edge is really noticeable, but it sounds as though it's the same as yours. Mine works fine, but I can't compare the construction of it to the kit zoom, I don't have one.
I just assumed it was how it should be.
Dan[/img]
Dan[/img]
Posted 08/01/2007 - 21:03
Tom,
Flush with metal ring? I was sure I rubbed my finger on a glass edge and not a metal ring. I would like to see the shot Matt.Tom,
Daniel has very kindly posted a shot of his which does look like mine.
Matt have you a kit lens or other to compare finishes?
Tom
Posted 08/01/2007 - 21:57
Tom,
Just tried snapping mine - but the image looks very similar to Daniel's.
However, that doesn't appear to be the edge of the element itself - if I run a finger nail from the edge of the element towards the lettering, it stops at the circular metal rim.
If, on the other hand you gently rub your finger over it - it feels rough (because you're feeling the metal rim, not the element). I've just examined mine from all directions and it definitely looks like a thin rim of metal around the edge of the element.
Contrary to what I said, the element is very, very slightly lower than the metal surround.
I have the 16-45, which is completely different in construction. I suspect they've squeezed the 50-200 into a very small space, but it is a bit strange that it feels "unfinished" on the front element.
In summary - not the best thing to cuddle and stroke ( LOL ), works a treat though as a lens
Posted 08/01/2007 - 22:07
Matt and Daniel
Thanks so much for helping me on this. In the morning, in the clear light of day when I'm not in need of a stroke or cuddle I'll unpack it again and have another look.
Tom
Tom
Posted 08/01/2007 - 22:27
I've had a close look at our 50-200mm and although the front element is proud of the mount, the finish is perfect. No rough edges at all.
Posted 09/01/2007 - 17:28
Mines smooth like John's - maybe a batch destined for samsung got mis-labelled?
Posted 09/01/2007 - 18:06
Hey, I have a Samsung 50-200 and it is as smoothe as a baby's bum.
I have no qualms with the quality and use it quite a lot. No offence taken.
Harry
Harry
Posted 09/01/2007 - 18:14
sounds like mine is identical to Matts. The metal ring is maybe as much as 1/2mm above the glass surface, both are above the printed writing. I haven't subjected mine to a macro lens to see how smooth it is (not keen on touching it, I'm paranoid about my front elements!)
Posted 09/01/2007 - 18:30
Mine is the same with the ring (which is very thin) a fraction above the glass surface
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
20 years
Staffordshire,
England
Jessops price = £179
