Pentax 12-24mm f4 users
Posted 02/01/2009 - 23:44
An unqualified "thumbs up" for the 12-24mm, a brilliant lens. Very accurate drawing (low distortion), super sharpness and an excellent all round performer.
Posted 03/01/2009 - 00:36
I too am a fan of primes but I have to say the 12-24 is the most "prime-like" zoom I've ever used. A big thumbs up from me too.
Joining the Q
Posted 03/01/2009 - 17:36
I'm starting to be persuaded now too...
I fancy a wide angle lens and was going to buy the DA16-45 but thought it may not be wide enough.
If i go for a wide angle lens i was looking at the DA12-24 or the Sigma 10-20. Although if i go for the Pentax it will have to be soon to get the cash back.
Posted 03/01/2009 - 20:50
Hi Marky
I have just taken the plunge and ordered one from amazon for £453
not sure will get cashback ,but if I do will be a bargain
Posted 03/01/2009 - 21:19
Hi all,
Many thanks for your replys.
I am going to have a look around and see this lens.
Is it possilbe to use Cokin P filters on the 12-24 without the filter or filter holder showing?
Also, can a UV filter be used without effecting the image. I think this lens has the SP coating, but with a bulbus glass, might need protecting.
Kind Regards
Graham
Kind Regards
Graham
K10d Grand Prix & Grip
10-17mm fisheye, 15mm Limited, 21mm Limited, 40mm Pancake Limited, 70mm Limited
Posted 04/01/2009 - 01:24
I use the Cokin P Wide Angle Holder (the one with just a single slot instead of the standard 3 slots) on this lens and it's invisible down to 13mm with barely perceptible edge shading at 12mm.Is it possilbe to use Cokin P filters on the 12-24 without the filter or filter holder showing?
I personally don't use a UV filter, I just make sure the hood's always attached. Shouldn't be any problem if you do want to use one though
Joining the Q
Posted 04/01/2009 - 14:05
The 12-24 has revolutionised my photography. It also taught me a few things:
I had to think harder about composition at wide angle.
Focus then recompose is very dangerous at wide angle.
The angle of the camera to the subject is very important(two examples being - faces at the edge of the image can seem distorted - keeping parallel lines parallel, such as walls when shooting inside).
Parden me for posting this if it seems obvious to the experts, but I hope this might help!
I have been amazed by the quality of what I've produced with this lens.
El Dingo - K3-II and K10D
Posted 04/01/2009 - 17:37
I do have a UV filter attached to mine with no problems. It is a lovely lens but as El Dingo said, ultra wide does require a bit of thought! I tend to have that lens attached to my camera most of the time even though I tend to use it more at the 24mm end.
Cheers, Kris.
Cheers, Kris.
Posted 22/01/2009 - 22:22
Hi all.
After much debate and reviewing, I got the 12-24 Pentax over the 10-20 Sigma.
I have sent the claim form away to claim the £50 back.
Any idea how long the cashback offer takes to return.
Hoping for some good weather now, so I can try out the new lens
Kind regards for your feedback on this topic.
Graham
Graham
Posted 23/01/2009 - 15:20
I have the DA12-24mm, its a great lens. Wide enough to use in a small space. Good colours and contrast.
The older I get the faster I was.
Dave
K-3 II, K10D, DA16-85, DA*50-135, DA12-24, DA18-55, DA 50, Sigma EX DG 70mm Macro, Sigma 70-300mm, Sigma DG 120-400mm APO HSM.
Metz 58 AF-1.
My Flickr link
Dave
Metz 58 AF-1.
My Flickr link
Dorset
Looking to get a wide angle. I use my 21mm limited as wide angle, but sometimes its just not wide enough.
So, im starting to have a look around.
What are your thoughts on the 12-24 f4? Is it worth the near £500 price mark.
Im also looking at the 14mm prime, as I like the prime lenses.
Both are expensive lenses, although there is £50 cash-back to help.
Kind Regards
Graham
