Pentax 100mm Macro
All this implies that the camera is on a tripod and you are making a series of pictures at the same focus point.
In macro work of the kind i have described, manual focus is also very much easier than autofocus.
http://www.ephotozine.com/article/Pentax-SMC-100mm-f28-D-FA-Macro
...or Limit, in which case it restricts it's search to the Macro range max 0.6m.
Dan
Dan
The FA lens is like a tank.
Both are excellent.
Dan
shim
The only trouble is the viewfinder of my K10D is a bit off for manual focusing with this lens.
If you are finding it difficult to see the point of sharpest focus, the dioptre adjustment may be wrongly set. Point the camera at a blank area of wall or sky (it's better if the lens is out of focus for this) and ajust the eyepiece until the guide lines are critically sharp. That will mean you are now focusing your eye on the ground glass screen and manual focusing should be much easier.
would the 100mm macro lens also double as a 100mm telephoto or does the construction to suit shot distance focus mean this is not practical
[IMG]http://i223.photobucket.com/albums/dd37/hefty1969/competition%20stuff/IMGP1614.jpg[/IMG]
[IMG]http://i223.photobucket.com/albums/dd37/hefty1969/competition%20stuff/IMGP1933.jpg[/IMG]
Of course it's pretty damn good at close range too...
shim
Set a tape up at 45deg. Cut the back corner off an asprin box and trimmed it to fit the tape so that I could focus at 100mm take a pic then move the box to one side and take another pic. Repeated this twice moving the camera slightly.
Setup
[IMG]http://i545.photobucket.com/albums/hh387/penbx/Setup_1.jpg[/IMG]
Results: Top two 50mm A f/2.8 Macro Lens
Bottom: 50mm f/1.4 FA Standard Lens : Left = Manual Focus : Right = AF
[IMG]http://i545.photobucket.com/albums/hh387/penbx/Compare_1.jpg[/IMG]
So it's not just the Macro that's back focusing the Standards doing it as well in both manual and AF. I might try adjusting the AF setting and seeing if it effects the Manual focus. If not it must be the viewfinder screen out of position.
shim
Many thanks.
